Miller Spectrum 2050 torch upgrade
Discussion forum for Lincoln & Miller plasma cutters
Mountain Home
Post by Mountain Home »
If anyone has a 2050 and would like to upgrade to a machine torch for under $500, you can buy a Hypertherm RT60 from Scott Gross online for $490. All it takes to use this torch on the Miller is taking the connection end apart and rearranging the pins to match the Miller. This works great.
Dana gear
Re: Miller Spectrum 2050 torch upgrade
Post by Dana gear »
Another option is Thermal Dynamics one torch. We installed one on our Miller 2050 and flat love it. Direct connection
Riverratfab
Post by Riverratfab »
Do you have any pictures of doing it I am trying to rig one up on my plasma cutter now
toschar
Post by toschar »
Yes I to would like to know the pin out to updrade thanks
cowboyupcustoms89
Post by cowboyupcustoms89 »
Hey guys so I am currently trying to upgrade to a machine torch on my 2050 I got the torch bought but what do I need to change over or add to get it to fire? because the plug and play method did not work unfortunately. is there a trigger part I will need to order to use the machine torch?
Reading the original post from Mountain Home it sounds like you have to re-arrange the pins to make it work. Try downloading the manuals for each plasma cutter and hopefully there will be a diagram showing the pin out of the torch plug of each machine.
Post by djreiswig »
Miller
Hypertherm
It looks like you need to move pin 7 in the torch to pin 3. That appears to be the only difference in the connections.
I found it interesting that the wire colors are the same between the two brands.
Return to “Lincoln & Miller Plasma Cutters”
