fire ring
Marcus
fire ring
Post by Marcus »
has any one made this and have the dxf file for it?
james.davis
Re: fire ring
Post by james.davis »
http://www.plasmaspider.com/download/fi ... 751b121ab6
I just drew this up pretty straight forward. As always check it before cutting.
Hope it helps.
Jim
firen ring.dxf
Binderman01
Re: fire ring
Post by Binderman01 »
Ive not looked at your file James. However I too tried to draw it and cut it and my legs did not match the angle of the firebox. How did you get your angle? I'll download it when I get home and see if your angle matches what I have
Marcus
Re: fire ring
Post by Marcus »
james.davis wrote:http://www.plasmaspider.com/download/fi ... 751b121ab6
Hope it helps.
Jim
have not looked at it yet but will when i get home. Thank you very much for your time!
Marcus
p m metals
Re: fire ring
Post by p m metals »
Has anyone tried this and put it together
p m metals
Re: fire ring
Jim is the one in the photo from your file? did you cut and put this together??
Lance G
Re: fire ring
Post by Lance G »
I was looking at this and it didnt line up very well for me so i tweeked a few things and i think this should work but please still check as i havent cut this.
hope this helps as i certainly appreciate all the help that ive been given on here.
Lance
firen ring.dxf
Lance G
Re: fire ring
Post by Lance G »
By the way scale to size as this is very small only 18.5" across the flats and about 26" corner to corner.
radnurse68
Re: fire ring
Post by radnurse68 »
If anyone is able to scale this up to 30 and 36 in I would be glad to pay you for it. I'm not sure how to do it and I was hoping to cut this for my kids school fundraiser. Hopefully I can get it tonight if possible. Thanks for any help I can get.
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
Davidsupershop
Re: fire ring
Post by Davidsupershop »
here it is 30 in. make sure you check it before you cut it.
firen ring 30 in.dxf
SNLLC
Re: fire ring
Post by SNLLC »
Davidsupershop wrote: Wed Apr 20, 2016 12:35 am here it is 30 in. make sure you check it before you cut it.
Has anyone cut/validated this 30" version?
Thanks for the work on this.
Metalfabcnc
Re: fire ring
Post by Metalfabcnc »
Does anyone know what gauge plate the slots were designed for?
- Mike Cote
Follow to see my latest work.
https://www.instagram.com/metalfabcnc
big496
Re: fire ring
Post by big496 »
Here is Davidsupershop's file that is posted. This is cut from 1/4" and it measures 30" diagonally.
Re: fire ring
big496 wrote: Wed Jun 08, 2022 10:48 pm Here is Davidsupershop's file that is posted. This is cut from 1/4" and it measures 30" diagonally.
:Like :Like :Like
shinertx
Re: fire ring
Post by shinertx »
nice fire pit.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
