I have been testing many prep methods. I am currently working with vinegar to remove rust and mill scale. I have had very good results. It is not as expensive as hydrochloric acid and while it has a pungent odor it is not as hazardous to your skin either.
I filled a 55 gallon trash can with 30 gallons of white vinegar and began soaking. Over a weeks time I soaked 20 large pieces, 8-24 hours, with good results. I went over the piece with steel wool and rinsed with water. Because I am anal about prep I also ran over it with wire wheel but I really do not think that was necessary. The steel wool etches it. I just like to see that shiny look before I cover it with a finish!
I have no idea how long the vinegar will stay potent. I did test paint removal with vinegar and while it took several days it does lift high heat paint. I easily scraped it off.
Removing mill scale with vinegar
- tnbndr
Re: Removing mill scale with vinegar
Not sure where you are located but look for a source of pickling vinegar, it is 12% acidic compared to the store vinegar at 4%.
I found a business near me that pickles eggs, etc for bar treats and they sell it to me for $1.75 a gallon.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Thanks for the tip!
