Another Lead In Issue
Post by tnbndr »
I have lead in set to .25 perpendicular and on most of the pieces it shows in SheetCam but sometimes one or two will not have a lead in shown or produced when cutting.
The object is a polyline just like the others.
Start point 33 below, no matter where I move it will not show the lead in as 34 above it does.
Any insight appreciated.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Re: Another Lead In Issue
Are they both using the same tool if not you may not have a lead in selected in that tool.
Another thing is there is no rapid showing to that part.
Les Newell
Post by Les Newell »
Could you post the job file so I can run some tests to find out what is going on.
Capstone
Post by Capstone »
I think #33 is an orphan node in the drawing and since it's a single point, it likely is being treated as a pierce.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
Post by tnbndr »
Acourtjester:
Yes, same tool. The rapid stays at the original start point no matter where I move it to.
Capstone:
There is no orphan node. I went to the original cad drawing and checked everything, it is a clean drawing.
To update this, I cut the file as it was and everything cut out fine, no lead in was cut at the start points in question.
When I import the file I get the message that "some paths were not generated correctly. There could be a problem with the drawing". I get this message frequently but when I check the job file in sheet cam for issues usually there are none, offsets are created, paths look good and the file cuts fine.
Using version 6.0.15 the latest stable version.
Les:
I posted a job file with the issue replicated. Note start points S8 and S14.
Les Newell
OK, that took me a while to find. If you zoom in really closely on the outline next to the actual start point you will see it is a rather strange shape. That is confusing the path generator. If you look closely at the cut path at that point you will see it is broken. SheetCam thinks this is an open path so it doesn't put in a leadin.
I have a suspicion this could be an artifact from arc matching. I am about to upload an update that has improved arc matching. Note arc matching only has an effect when you import a drawing. Could I have a copy of that drawing so I can run some tests on it.
Post by tnbndr »
Les:
I am attaching a zip file with the dxf and job file, if you need a different format let me know.
I do know that piece is a closed polyline, I checked and rechecked, so is whatever is happening being done by SheetCam? Dan at LDR tells me I have the weirdest crap happen all the time!!! :o
sphurley
Post by sphurley »
It does not like two of your pieces, not sure why they look fine in all my cad programs. When I delete those and copy and paste another one of the parts it works fine.
12ga3.zip
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Post by tnbndr »
Yep, I did the same. But from what Les has posted and is investigating I think it is a SheetCam issue and not CAD. Will wait for the verdict to come back.
Les Newell
I had a look at the drawing. If you zoom in closely on the drawing where the cut actually starts there is definitely something odd in the dxf file. I originally thought it might be a problem with SheetCam's arc detection but it is definitely in the drawing. I have attached a couple of images of the problem area.
This a close up of the problem area. If you zoom in really close on the right hand part of that arc you will see a small overlap. Overlaps really confuse the path generator.
Post by tnbndr »
Wow, thanks for the look see. I went over those items many times. Actually I can zoom in and see what you have but when I try to fix it remains the same. I just deleted the offending parts and copied another that works.
sphurley
Post by sphurley »
I see it now also. There are nodes there when I deleted two of them it worked.
12ga_fixed.dxf
badNodes.pdf
Miller 350P
Return to “SheetCam”
