Steel Moving Equipment
I am trying to find some plans for a lift or some piece of equipment that I can move my steel from the stack to the table. I am needing some type of device or lift because my 17 year old will be gone in another year, and, as we all know, 4 X 8 sheets of steel are not easy to move. Any help with a lift design would be greatly appreciated. I don't know if I want to buy a forklift or make something to move the steel. Thanks
Boyd Fortin
Boyd Fortin
Re: Steel Moving Equipment
Get one of the magnets. You can find them on ebay. I bought 2 of the 1400 pounders and they are great. I use my skid loader but you can use a engine puller which is what most guys use.
Check out what Sean P developed for moving thinner sheets. I think he had 2 post with different ideas here is one
http://www.plasmaspider.com/viewtopic.p ... ver#p90055
- SeanP
Yes that's one that acourtjester posted link to that I modified the sack truck, must say it works great, a 6mm 8 x 4 sheet would be about the limit, but I keep 1/2 sheets in 12mm for small parts, it will move those about fine too, one mod I did add was to add a strip of rubber on the wood cross piece for extra grip.
I keep thinking I might make some sort of trolley to do the same job as clipping the brackets onto the table.
https://www.youtube.com/watch?v=ubyRYxWP4dU
Here is the other contraption I came up with for getting full sheets off the truck onto the table, works great no problem at all with 12mm - 8x4 sheets.
I was also wondering about a fork lift or some sort of hoist, but went for the easiest cheapest option and it works just fine.
https://www.youtube.com/watch?v=hYwryq0O-q4
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- SeanP
I made up the rollers all on the table, 6mm washers with 12mm hole, cut the slots and holes as well.
Powermax XP45
Table build gallery
Table build gallery
Thanks for all of the good ideas. I will figure out the route I go and let everyone know. Thanks.
Boyd Fortin
Boyd Fortin
- _Ogre
hats off to seanp
necessity is the mother of invention
both ideas are ingenious
an ogre smiley
how cool!
an ogre smiley
- SeanP
Go on then,,,,here is another one for all you loggers
https://www.youtube.com/watch?v=zLMSbXQjvQ4
_Ogre wrote:hats off to seanp![]()
Powermax XP45
Table build gallery
Table build gallery
Sweet rig for the saw SeanP. I'm going to have to build one of those. Thanks
I would love to see some ideas on moving sheet. I too am a single man outfit, in VERY tight quarters...
- SeanP
Old bandsaw blade for the springy bit is ideal.eggauto wrote:Sweet rig for the saw SeanP. I'm going to have to build one of those. Thanks
Powermax XP45
Table build gallery
Table build gallery
- tnbndr
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Thanks for the tip SeanP
- HammerDownJustin
I have used a cherry picker..roll around gantry crane.. 4 people grabbing a corner of 3/8" plate and a prybar to center it. I gave in and bought a 40' long 3" i-beam about 2 months ago and it was the best choice I have made. I built a trolley and the beam is supported every 20'. On the trolley is a northern tool winch. I think I could run my table while on crutches now if needed.
Miller 251 Mig
Miller 251 Mig
- Larry83301
HammerDownJustin wrote: I think I could run my table while on crutches now if needed.
Well, let's hope you don't have to!
- HammerDownJustin
Lol I hope not..but a year and a half ago had to have a emergency knee replacement.. It opened my eyes and made me plan for the worse just incase.Larry83301 wrote:HammerDownJustin wrote: I think I could run my table while on crutches now if needed.
Well, let's hope you don't have to!![]()
Miller 251 Mig
Miller 251 Mig
