sheetcam importing to small for some reason??
- HammerDownJustin
Curious if anyone else has ever had this issue. happened once before and seemed to fix its self. Only happens on full sheet programs to me. Got a crap load to cut a full sheet and for some reason when bringing to sheetcam it is shrinking everything from 95"x 46" to about 1.5" x 3". Have no clue why. Using a dxf file from corel x4. Fixing to try opening in corel x7 and see if i resave if it fixes. So much on it sheetcam doesnt want to open the svg file for some reason. Just curious if anyone else has ever ran into this before. thank you
Miller 251 Mig
Miller 251 Mig
- chasxjs
Re: sheetcam importing to small for some reason??
Sounds like it might be importing it as metric.
Have you checked the scale?
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
Hypertherm PM45
Shopsmith Lathe
- HammerDownJustin
Thank you sir yes it was. Seen it and came back to post it..lol..thank you and have no clue why it went back to metric crap. Even my svg import side went back to 1:25 factory setting instead of 1:1 hopefully someday this helps someone else
Miller 251 Mig
Miller 251 Mig
- chasxjs
LOL ...... after years of working in the automotive industry, my MIND tends to go back and forth from SAE to metric.
Glad you got it sorted out.
Charles
Hypertherm PM45
Shopsmith Lathe
Hypertherm PM45
Shopsmith Lathe
I have had problems with SheetCam not saving setting and when I go in to do another drawing things are not what I had set it to. This is manly with tool setting for the arc voltage. I just check it each time when I go in when starting new jobs. I have save the tool file and default setting many times but they do not hold. When ever there is an up-date things seem to revert back also that may be where your's changed back too.
- _Ogre
i wish we'd just convert to metric myselfHammerDownJustin wrote:metric crap
i can do 10s in my head easy enough
not so good with 12s, 16s, 32s, ft, yds, lbs and ozs
an ogre smiley
how cool!
an ogre smiley
- HammerDownJustin
Yeah im just to used to American after all these years.. some day it will offend someone and we will switch..lol_Ogre wrote:i wish we'd just convert to metric myselfHammerDownJustin wrote:metric crap
Miller 251 Mig
Miller 251 Mig
- exapprentice
Hi "HammerDownJustin"
is what you call "American" the same as the old english system of fractions and thou's
we changed back in the seventies, it was a real PTA to start with trying to work between english and metric but once you get used to it its great
Like Ogre says doing the numbers is real simple when its all in tens
Cant be that many countries left in the world that are still using feet & inches most of the auto industry is now metric
even the thread system is easy just one format no more BSF, Whitworth, BA, UNC, UNF threads just metric
honest its not that bad a deal to go metric
Only my opinion as having worked with both systems I just prefer the simple option
Best Regards to all
Exapprentice
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting
Exapprentice
(Pete)
You guys are funny when was the last time you programmed your machine in 16ths or 32nd ???? You ARE working in tenths in the decimal system. The bad part about Working in MM is the HUGE numbers you end up working with. And yes I have worked in both since teh 60's .
(;-) TP
(;-) TP
I too started school with imperial but metric came in as the standard so I learnt both.
It did make a difference though, I used to weigh 220 pounds but thanks to metric now I'm only 100 kilo's. I used to struggle to walk 5 miles but now I do 8 kilometers, it always seemed hot at 100 degrees but 36 doesn't sound so bad and my car that used to go 100 miles an hour now does 180 kph. The best part was the hundred pound I had in the bank became 200 bucks.
Murray
Murray
