Edge start
Leeds88
Edge start
Post by Leeds88 »
Hi
I've got some 25mm mild steel that I need to cut on my table. I have a hypertherm 105, it says in the manual to do a edge start but can't seem to do it!!
My torch needs to have the material directly under it otherwise it won't arc, it just miss fires.
djreiswig
Re: Edge start
Post by djreiswig »
Put a scrap next to the edge where the start is to give the arc something to bite into.
WyoGreen
Re: Edge start
Post by WyoGreen »
Edge starting is a bit tricky. You either put a scrap next to it as Dreiswig suggested, or position the torch so it is just a bit over halfway over the material to be cut.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
Leeds88
Re: Edge start
Post by Leeds88 »
ok thanks guys I will use a bit of scrap then!!
Re: Edge start
Post by jimcolt »
Edge start is easy....line up the center of the shield orifice directly on the edge. Use about a 2 second pierce delay time and about a .12" pierce height. Jim Colt Hypertherm
tnbndr
Re: Edge start
Post by tnbndr »
You could set the machine to the perf metal setting also, just to be sure not to lose arc
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
