My attempt at the "support our troops" eagle
cpstang1967
Post by cpstang1967 »
Not sure I took the best approach to the red and white feathers, but I'm happy with how it turned out for being a first attempt. Definitely learned a couple tricks on this one. Next piece should be a little less time consuming (and a few less curse words)
Re: My attempt at the "support our troops" eagle
Looks nice! Thanks for posting the pictures.
joe@jjdesign.us
Post by joe@jjdesign.us »
great job very nice
Semper Fi,
little blue choo
Post by little blue choo »
Awesome job.
Rick
Rick
Arclight 9600 4x8 table
larrycameron44
Post by larrycameron44 »
Yep, that is very very cool!
Great Job.
jpmreno
Post by jpmreno »
Looks really kool
jpmreno
cpstang1967
Thanks everyone.
Contiveros
Post by Contiveros »
Good Day and wonderful art piece,
It's a outstanding work of craftsmanship detailed to "Support the Troops". As a Retired military DAV myself its good to see individuals like yourself giving back to the community.
Thank You
Cornelio Ontiveros
San Antonio. Texas
Retired SSgt USAF joint serve Army
DAV
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
SlagBandit
Post by SlagBandit »
Hmm don't remember posting this file or sending it....
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
cpstang1967
Contiveros, thank you for your service and thank you for the encouraging words.
cpstang1967
SlagBandit wrote:Hmm don't remember posting this file or sending it....
I'm not sure if this is meant to ask if I copied the file, or if you're just sharing your work. Either way, I really like the way you worked with the depth of the individual pieces. Also, great idea with curling the feathers forward.
However, if this was intended to make a point about possibly copying, I assume we both designed off the same window decal? If you look closely, almost every aspect of every piece is slightly different. You have cuts on the red and white where I do not. Your blue body feathers go much farther down the body than mine do. Your head is completely different and appears to be the same piece as the background where mine is a separate piece attached to the blue feathers. We also took a different approach for the stars. You cut each star out where I used decals. Same goes for the talons. It also appears that you cut the beak out where I decided to make that a separate piece as well. That being said, I do think we both had the same idea for a paint scheme. :lol:
If you feel this work was copied off of something you've created, I can assure you that it was not, but I would be more than glad to remove the post to prevent any hard feelings.
Keep up the good work,
Cody
