My attempt at the "support our troops" eagle
Not sure I took the best approach to the red and white feathers, but I'm happy with how it turned out for being a first attempt. Definitely learned a couple tricks on this one. Next piece should be a little less time consuming (and a few less curse words)
- Larry83301
Re: My attempt at the "support our troops" eagle
Looks nice! Thanks for posting the pictures.
great job very nice
Semper Fi,
Semper Fi,
- little blue choo
Awesome job.
Rick
Rick
Rick
Arclight 9600 4x8 table
- larrycameron44
Yep, that is very very cool!
Great Job.
Great Job.
Thanks everyone.
Good Day and wonderful art piece,
It's a outstanding work of craftsmanship detailed to "Support the Troops". As a Retired military DAV myself its good to see individuals like yourself giving back to the community.
Thank You
Cornelio Ontiveros
San Antonio. Texas
Retired SSgt USAF joint serve Army
DAV
Thank You
Cornelio Ontiveros
San Antonio. Texas
DAV
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
- SlagBandit
Hmm don't remember posting this file or sending it....
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
Torchmate 1 5x10
Miller 225 MIG
Contiveros, thank you for your service and thank you for the encouraging words.
I'm not sure if this is meant to ask if I copied the file, or if you're just sharing your work. Either way, I really like the way you worked with the depth of the individual pieces. Also, great idea with curling the feathers forward.SlagBandit wrote:Hmm don't remember posting this file or sending it....
However, if this was intended to make a point about possibly copying, I assume we both designed off the same window decal? If you look closely, almost every aspect of every piece is slightly different. You have cuts on the red and white where I do not. Your blue body feathers go much farther down the body than mine do. Your head is completely different and appears to be the same piece as the background where mine is a separate piece attached to the blue feathers. We also took a different approach for the stars. You cut each star out where I used decals. Same goes for the talons. It also appears that you cut the beak out where I decided to make that a separate piece as well. That being said, I do think we both had the same idea for a paint scheme.
If you feel this work was copied off of something you've created, I can assure you that it was not, but I would be more than glad to remove the post to prevent any hard feelings.
Keep up the good work,
Cody
