Fairly new to using this machine. Used a smaller model in the past. Been using problem free for a couple months until today when I went to change consumables the water was spraying out Lol.. any ideas? I k ow it purges a little but it’s way way too much
Thanks for any ideas!
XRP 300 plasma head gushing water/coolant?
Re: XRP 300 plasma head gushing water/coolant?
Steve - it sounds like you've got one of their high definition cutters - probably not too many here familiar with that cutter, but I would suggest taking a look at your manual for an exploded view of the torch head. Perhaps you have a damaged o-ring allowing the leak. I think it should be pretty self-evident once you take it apart to check it. Let us know how you make out.
https://www.hypertherm.com/en-US/suppor ... ish%20(US)
If it was spraying uniformly like a sprinkler then its because there is still coolant pressure. Need to set the button on the screen that rotates between manual/auto/off to off so there is no coolant pressure and then take the torch head off.
Great to point out for future reference buy others
Same thing happened at my work . Could not figure out the issue , now using brand new head .
