XRP 300 plasma head gushing water/coolant?
Steve-O
Post by Steve-O »
Fairly new to using this machine. Used a smaller model in the past. Been using problem free for a couple months until today when I went to change consumables the water was spraying out Lol.. any ideas? I k ow it purges a little but it’s way way too much
Thanks for any ideas!
Re: XRP 300 plasma head gushing water/coolant?
Steve - it sounds like you've got one of their high definition cutters - probably not too many here familiar with that cutter, but I would suggest taking a look at your manual for an exploded view of the torch head. Perhaps you have a damaged o-ring allowing the leak. I think it should be pretty self-evident once you take it apart to check it. Let us know how you make out.
https://www.hypertherm.com/en-US/suppor ... ish%20(US)
xpr300 -1.jpg (66.57 KiB) Viewed 1330 times
xpr300 -2.jpg (130.1 KiB) Viewed 1330 times
xpr300 -3.jpg (119.69 KiB) Viewed 1330 times
xpr300 -4.jpg (88.53 KiB) Viewed 1330 times
JakeGG
Post by JakeGG »
If it was spraying uniformly like a sprinkler then its because there is still coolant pressure. Need to set the button on the screen that rotates between manual/auto/off to off so there is no coolant pressure and then take the torch head off.
weldguy
Post by weldguy »
JakeGG wrote: Fri Jul 01, 2022 11:02 am If it was spraying uniformly like a sprinkler then its because there is still coolant pressure. Need to set the button on the screen that rotates between manual/auto/off to off so there is no coolant pressure and then take the torch head off.
Great to point out for future reference buy others :Like :Like
Kanwar
Post by Kanwar »
Same thing happened at my work . Could not figure out the issue , now using brand new head .
