Snoopy & The Great Pumpkin
Jfile
Post by Jfile »
Would someone mind taking a look at this drawing and see if you see any obvious mistakes before I attempt to cut please? This is my first trace and I'm not really sure how some of these cuts will play out. For example, the lines on the leaves on each side of the pumpkin... will the torch just make a pass and cut the line the width of the kerf or will it ignore a line that is just standing alone like that?
I do think that I need to go back and adjust those cuts inside of the pumpkin. The ones that run vertical on each side. They seem to measure almost a 1/2 inch wide and I think they should be about 1/4 inch wide.
Anyway, this was my first trace and I'm not very confident in it so I hate to waste a 2 foot piece of metal if there are obvious mistakes.
Thank you in advance for any feedback or advice.
Snoopy and Great Pumpkin.dxf
LDR 4'x4' Water Table
Command CNC Linux Controller
InkScape / SheetCam
rdj357
Re: Check dxf please...
Post by rdj357 »
Looks good to me - not sure how your software will handle it but there were a few paths that didn't quite make it to join up and a couple places where there were some extra nodes but overall it would probably cut just fine.
Here it is after I did the little minor cleanup in case you want to compare.
Snoopy and GP Revised.dxf
harrymorley
Re: Snoopy & The Great Pumpkin
Post by harrymorley »
thanks for the share..looks great
Rtodahl01
Post by Rtodahl01 »
looks good I will try it
Vanquish
Post by Vanquish »
Thanks.
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Fatbastard
Post by Fatbastard »
Thank you everybody loved it....
Chip
ggeh
Post by ggeh »
Love it thanks for sharing
sonbakler
Post by sonbakler »
This is great, going to cut one for Halloween. Thanks for the share!
gslavik
Post by gslavik »
Nice work, Thank you for sharing!
avengermike
Post by avengermike »
