issues zeroing mach
elvenhome21
issues zeroing mach
Post by elvenhome21 »
Im having some problems getting mach3 to zero absolute when doing the reference all. I dont have limit switchs installed yet but even with the cover of the blade runner box and shorting the x and/or y home limit connections, the table will keep moving and not zero or stop. Im pretty sure I have the correct boxes checked in the homing screen because I followed what the arcsoft tutorial said it should be set as for my application. Z doesnt zero or stop either and that one has a switch built into it.
Another issue i had is when I took the cover off the small round cable that connects to the cover fell off and im not sure how it goes back on. its a 5 pin connector on 4 pin board with I believe only 3 wires so it can be plugged i about 10 different ways.
bladerunner
precision plasma table
Bonzi Metalworks
muzza
Re: issues zeroing mach
Post by muzza »
elvenhome21 wrote:because I followed what the arcsoft tutorial
Have you set it up going by the candcnc bladerunner manual as there are differences to the arcsoft instructions ?
You are also running the version which came with your bladerunner too and not a downloaded version from Arcsoft aren't you?
elvenhome21 wrote:Another issue i had is when I took the cover off the small round cable that connects to the cover fell off and im not sure how it goes back on. its a 5 pin connector on 4 pin board with I believe only 3 wires so it can be plugged i about 10 different ways.
bladerunner
I too had this problem, it must only be installed the right way which I also found in the manual Rev#1 4/3/2012 on page 43
Murray
Return to “Mach3 & Mach4 CNC”
