first time cutting 3/8"s steel
kel fab creations
Post by kel fab creations »
I cut some 3/8's steel today for the first time. I'm using my 22+ year old hypertherm max 42 (40amp) with an RT60 torch. The cut chart for my plasma stops at 1/4" so I looked at a pm45 cut chart and made sure I was a little slower than that. I cut this at 25ipm and I am very happy with the results. Holes were cut at 15ipm. Piercing was a bit of a chore but it did do it without messing up the nozzle. By the look of the dross I can speed up a little right? I just don't wanna sacrifice edge anglularity.
Cleaned up easy.
Re: first time cutting 3/8"s steel
Post by jimcolt »
Keep increasing the speed by 2 to 5 ipm on successive cuts.....at a point the dross will be either minimal or non-existant. Write that speed down for next time. Cut your holes at 60% of the dross free speed.....and you will get good repeatable results.
The cut height should maintain at about .06" to .08" with that plasma....and the pierce height should be at about .12" to .16" for best nozzle/shield life.
Jim Colt
twicecustom
Post by twicecustom »
Very nice!!! And pretty fancy welds there too!
Jack of all trades, Master of none.
Benjiman
Loyd
Post by Loyd »
Those are some good looking parts! Nice job! And Jim, thanks for the tips!
Loyd
JJsCustomDesigns
Post by JJsCustomDesigns »
I cant ever get my holes to look that nice. i usually have to make them 1/8" smaller and drill em out with the drill press. Nice work!
PM me with details
kel fab creations
Thanks for the compliments guys. I actually did cut the holes 1/16" smaller and drilled them out after.
Post by jimcolt »
Using proper technique (a good plasma, consumables in good shape, proper power level, correct pierce and cut height, correct lead in lead out shapes and correct hole speed) you can get nice holes that generally don't require drilling.
Attached are pics of 3/8" and 1/4" parts....the 3/8" has holes as small as 3/8" that you can drop a bolt through...the 1/4" has holes as small as 3/16" . All cut on PlasmaCam with Powermax at 45 amps (shielded consumables).
Jim
alleykat
Post by alleykat »
Kel Fab,are those wheel spacers you made?
kel fab creations
Yes they are. For my buddies 57 Chevy pickup.
