Hi
Can someone help me with wire digram.
I need to connet premier plasma 65 torch retainer wire to mach 3 controller.
Ohmic clip connection on Premier Plasma
Re: Ohmic clip connection on Premier Plasma
I need help.
Where do I connect the retainer wire on from torch.
You will need an Ohmic sensor module for Mach to use the circuit, I use a simple module from eBay, many have used what is called a "Water Switch" These have been hard for find lately. This is what I use, you can get them in 5,12, and 24 volt versions. Simple to wire up and add to Mach or other controller software, as a probe input. You will also need to use a post processor that is setup for the probe action in the G-code this is a G31 command for the Z axis. I can supply you with the circuit wiring (I need to find it on my HD) and a Post Processor if you use SheetCam.
https://www.ebay.com/itm/401188750996?var=670761872997
Here is the circuit and a description. I have used this setup on a few table for both Plasma ohmic sensor and bit tip detection on routers works great.
3-d printed a small box for it in the controller cabinet.
