I've got a Hypertherm powermax 85 which uses a duramax torch. Is there an aftermarket hand held torch available?
Thx
Aftermarket Duramax Torch
Re: Aftermarket Duramax Torch
Not sure if you can find one other then from Hypertherm, torch designs may be different. And also the plug on the lead matching the Hypertherm's panel.
- SegoMan DeSigns
Like Tom says OEM is the only way to go, did this come with a machine torch for the plasma table? SYNC or non SYNC?
when I bought the machine it came with a duramax machine torch. I know other mfgs. make MIG guns for different machines didn't know about a plasma.
- SegoMan DeSigns
These are for the older Non "SYNC" system / 75* hand torch:
25'
https://bakersgas.com/products/hyperthe ... 4403366965
50'
https://bakersgas.com/products/hyperthe ... 4404218933
75'
is available as well
Here is the download section for your 85 machine, save all docs to your hard drive for future use
https://www.hypertherm.com/en-US/resour ... ish%20(US)
25'
50'
75'
I know Thermacut makes aftermarket torches for the Powermax.
For best results stick with the OEM Hypertherm torch and consumables.
