Hello,
I have decided to build my own plasma cnc table but I dont think i will be machining the z axis. This is something that I will buy already fabbed.
Velox makes a nice one https://www.veloxcnc.com/xz-za-series but it is not magnetic breakaway
candcnc makes one but its UGLY for a machined piece https://www.candcnc.net/store-home/supe ... ch-holder/
So who else makes a Z Axis with a magnetic break away?
Thanks in advance!
Who Makes The Best Break Away Z Axis
Re: Who Makes The Best Break Away Z Axis
I've had a go at 3d printing one similar to this idea
viewtopic.php?f=122&t=30264
Yet to be given enough of a work testing in use to see how it stands up. It is very light and very strong.... But concerned with any blowback over time (I may add a thin metal shield to the bottom edge)
I picked one of these cheap z axis up from Amazon on next day delivery to try out (search for linear slide 100mm)
https://uk-m.banggood.com/100mm-Long-St ... cAQAvD_BwE
Also check the DIY version from seanp here on this forum
viewtopic.php?f=103&t=24499&p=152510#p149639
Its certainly much simpler to make than the one I machined. This and a pre-made Z axis stage like Robert linked to would be very cost effective.
I made one as well. I think my build has it in my sig. Also did a vid or 2 on it on my YT channel. I think I got my magnets from K G magnets. My vid lists it. YT username: TJS Welding and Fabrication.
Karve cut makes some
