Here are some links with plenty of information from how a plasma works to some very nice and detailed diy build logs, ranging from 4x4' to 15 meters or 45' .
This is an effort to gather as much info as possible in one place for those interested in building a DIY cnc plasma cutter, or retrofitting and old plasma machine. It includes some of the more detailed builds from this forum, plenty of info about mechanical design, motors, floating heads, grounding and shielding.
Links:
Plasma cnc primer:
http://linuxcnc.org/docs/devel/html/pla ... rimer.html
CNC Plasma cutters, general idea and a lots of info for building them:
https://forum.linuxcnc.org/plasma-laser ... ot-of-info
Rods "Spaceship" Scratch built Plasma Cutter build, a diy build with lots of details and info on building your own cnc plasma cutting machine:
https://forum.linuxcnc.org/show-your-st ... tter-build
A2 MechShop Gantry Plasma Machine:
http://wiki.linuxcnc.org/cgi-bin/wiki.p ... smaMachine
Scratch Built 4' x 2' Plasma Table, a very nice smaller DIY machine:
https://forum.linuxcnc.org/show-your-st ... asma-table
Plasma Table HAL example and a 9-part video series, very detailed instructions and nicely done videos:
https://forum.linuxcnc.org/47-hal-examp ... deo-series
3.5X1.5 Meters cnc plasma cutter, some ideas for reductions with rack and pinion drive:
https://forum.linuxcnc.org/plasma-laser ... sma-cutter
15m Industrial Plasma Cutter, discussion and some ideas of building industrial machines and the differences in design and implementation:
https://www.forum.linuxcnc.org/38-gener ... er?start=0
CNC plasma tube cutter, not much there but it is useful for getting a general idea for tube cutters:
https://forum.linuxcnc.org/show-your-st ... ube-cutter
Detailed log of building two identical machines with 3X2M and 2.5X1.5M cutting area, fully belt driven on all axis except Z that will use leadscrews, SBR 30 and SBR 20 supported round linear rails, high quality Lam Technologies drives, Mesa THCAD, Mesa 7i92, Sanyo stepper motors, etc :
https://forum.linuxcnc.org/show-your-st ... ld?start=0
-If i missed something, please do add the links below.
Thank you.
DIY or how to build cnc plasma cutter machine, everything in one place
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- ↳ Introduce Yourself
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
