Red Fish or Red Drum
saighusa
Post by saighusa »
Here is a Red Fish or Red Drum. I used a patina and clear coat on this fish.
KAP Red Fish 2D.dxf
KAP Red Fish 2.pcm
Re: Red Fish or Red Drum
Awesome! Thank you :D
ggeh
Post by ggeh »
Great job it looks real thanks for the sharing
Ok question did you use a scribe to mark the mouth, gills, and some of the scales on the fish. as the white behind does not show through? :o :lol:
Nice looking fish
larrycameron44
Post by larrycameron44 »
acourtjester wrote:Ok question did you use a scribe to mark the mouth, gills, and some of the scales on the fish. as the white behind does not show through? :o :lol:
Nice looking fish
It looks just like a single kerf cut. From slight angle you won’t see through.
Larry Cameron
RusticMetalArt
Thanks Larry still not convinced :lol: You may be correct, but after studying the image it appears the picture was taken straight on.
Look carefully and you can make out a dress and legs reflected from the picture taker :lol: :lol:
Maybe saighusa will solve the question :)
saighusa
Post by saighusa »
The mouth, gills, scales, fish are all cut using a fine cut nozzle. Sorry about the slow reply. I get a .037 kerf using it.
saighusa
Post by saighusa »
Forgot to add; you can see on the pcm or dxf these are cut paths. Thanks.
Thanks for the reply :D end of story :lol:
Bigjoe
Post by Bigjoe »
very nice, my favorite fish
kgc1031
Post by kgc1031 »
Love the patina color! I airbrushed mine and the color was more orange. I couldn't find the copper transparent color. I will have to keep in mind of patina. Great Job!
jallenmoore09
Post by jallenmoore09 »
thanks!!! looks great!!
jlb8748
Post by jlb8748 »
For some reason when I load this into Command CNC I see all the code but not the fish, and when I press run nothing happens. This is the only file it's happened to me with. Any ideas? It loads into plasmacan fine, I set all my layers and operations like any other file. No idea what's going on.
david jordan
Post by david jordan »
Nice job, thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
odha
Post by odha »
Thank you for the share - the red fish looks great!
