Sheetcam Gone Crazy
Sheetcam Gone Crazy
I have not one single clue what is going on here. A few months back one of the members shared a file that was a tattered American flag. This is that file. I downloaded it, copied to the thumb drive, and then put it in Sheetcam to cut. This picture is the screen after I created the operation???? It did the same thing with the dxf and the svg.
- WyoGreen
Re: Sheetcam Gone Crazy
If it was the one posted in Jan, "American Flag Tattered.dxf", that dxf needs a little work. When I look at it in Sheetcam, there are a lot of open lines touching that are not joined, so there is no clear outer cut. I suspect those lines just drove Sheetcam nuts. I'd probably do some editing on the dxf before importing it to Sheetcam.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
You have some settings OFF it sheetcam It looks as if you have the use actual tool size wrong and it makes HUGE WIDE toolpaths.
