how to use dxf files in the design edge
I am wondering how to make the dxf files show up or work on my plasma cam design edge software. The only pictures or files that i can get to view is the ones that are pcm. Any help would be greatly appreciated.
Re: how to use dxf files in the design edge
Open DE. File, import file, select the dxf and click ok. Should load right up. You can export as a dxf instead of a pcm file as well.
Shane
Shane
Thank you very much.
