Smoothing the curves on a DXF
grindergary
Post by grindergary »
I am wanting to try to cut this cross from this post http://www.plasmaspider.com/viewtopic.p ... oss#p42283
When I put it in X6, it looks not bad but when I tried to cut it , the torch would act like it was start and stop at each node in all the curves. Of coarse, this made a mess and burned some of the parts apart.
Can someone tell me how to smooth the curves so as to get a nice cut. I am a noob at Corel so any info would be appreciated.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Team Tracker
Re: Smoothing the curves on a DXF
Post by Team Tracker »
Hi Gary
First off select all objects by:
-dropping down the Edit menu clicking Select All-Objects
-drop down the Arrange menu and click on Join Curves to join all the little broken line segments that make up the drawing
-drop down the Arrange menu and click on Ungroup All to ungroup all the joined objects
-click on blank screen so no objects are selected then click on just the outer cross profile to select it
-select your Shape Tool (second tool from top of toolbar) or just press F10 to get Shape Tool and the nodes on the profile will show up
-look above your horizontal ruler for the Select All Nodes button and click it to select all nodes which will now be solid blue
-beside the Select All Nodes button is a slider bar that is now active, its called Reduce Nodes, click and hold on the slider and move your mouse to the right while holding the mouse button down and it will reduce the nodes and smooth the profile, if you go to far your profile will distort but once you find the sweet spot on the slider the profile will be smooth and the shape will still be correct
-complete this on all profiles you wish to smooth and be sure to save your progress each step of the way
If these instructions don't work or don't seem to make sense let me know. Hope this helps.
1-800-590-7804
grindergary
Reid T,
Works like it is supposed to. Thank you for the quick lesson!
Gary
Sheetcam, Mach 3
plain ol Bill
Post by plain ol Bill »
Reid what version of CorelDraw are you using?
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
JJsCustomDesigns
Post by JJsCustomDesigns »
Wish there was something like this for CorelDrawX4 :(
PM me with details
muzza
Post by muzza »
JJsCustomDesigns wrote:Wish there was something like this for CorelDrawX4 :(
There is, an upgrade to X5 or X6 ;) :lol: :lol:
sorry Aussie humour
SignTorch Vector Art
Post by SignTorch Vector Art »
I'm pretty sure it was in X3 if not before
If it doesn't show up on the property bar when you have the node tool selected
then you can go in options/customization/commands and drag the reduce-nodes tool to a toolbar somewhere
JJsCustomDesigns
Holy hell... that works great. Always learning new stuff
Thanks Signtorch
PM me with details
Dawgonhawg
Post by Dawgonhawg »
Good info. Thanks
Team Tracker
plain ol Bill wrote:Reid what version of CorelDraw are you using?
I am using CorelDraw X6.
1-800-590-7804
762frmafr
Post by 762frmafr »
Reid T wrote:Hi Gary
I am not disputing whether this method works or not, as I am sure it does. In fact, I learned everything I know about Corel from Youtube and trila and error. Here is my method for "smooting" a DXF like this one. Everyone feel free to chime in and let me know if this method gets the same results and other opinions please.
First thing I would do would be to take my pick tool and select the whole object. Then I would use my Boundary hot key, or got to Arrange then boundary and make an outside boundary.
Then for my program I would put this under the outside layer.
Then I would create an inside layer and then select my smart fill tool.
I would then fill in all of the inside "cuts". Which would then be automatically placed in the inside layer.
After that, you can then erase the original curves.
For the sake of my brain though, I go back and Boundary all of the smart fill curves and erase the smart fill.
Seems to work for me. Then this way, it is easy for me to choose inside and outside in sheetcam as well. What do the people that know Corel better than I say?
Team Tracker
762frmafr wrote:Hi Gary
That's the thing about Corel, there are often times many ways to get to the same end result.
I may be missing something but how do you get a smoothed profile when you fill the original profile and use the outline from that?
See image below smoothed with the technique I described. Are you able to do this with your technique?
1-800-590-7804
762frmafr
Post by 762frmafr »
I see what you mean now. What mine does is reduce nodes. Which I thought was the OP's original question. I have never magnified it enough to know whether I am "smoothing" it like you illustrated. Next time I will for sure and report back. Maybe I was way off base.
muzza
Post by muzza »
When you look at the preview of that file you can see that there are lots of straight lines. I imported the file into X5 and it had 2323 objects (line segments) so was never going to be a smooth flowing file. Simply by using the join curves function it reduced it to 54 objects.
After that was done by selecting all of the file I converted to curves and then selected one section at a time and reduced nodes to smooth the design. I only did a few sections to make sure it made it smooth and flowing.
May be a quicker easier way but that's how I generally tackle a file like that with lots of straight segments.
The other way I have done it that sometimes works is to save the file as a bmp file and then to an autotrace in Corel and smooth it in the trace.
Murray
