Off Topic - Sweet Custom Press Break
All topics related to bending, forming, notching, drilling, saw cutting, etc.
Re: Off Topic - Sweet Custom Press Break
SegoMan DeSigns wrote: Thu Jun 30, 2022 12:49 pm David,
That is a nice clean simple setup, I refer to that as KISS engineering (Keep It Simple Steve) :Yay
How is the IGaging DRO holding up? I was going to install one on each bay for U/D and one on a steeper controlled back stop in the middle section.
The IGaging DRO has been very reliable since installation about 4 years ago. I also have 4 pairs of the IGaging digital calipers and much prefer them to my Mitutoyos. I've also got some of the IGaging digital inclinometers that work very well as well. They are magnetic and I have used them attached to the parts I am bending to measure the bend angles.
SegoMan DeSigns
Post by SegoMan DeSigns »
adbuch wrote: Thu Jun 30, 2022 6:43 pm
:Like :Like
SegoMan DeSigns
SegoMan DeSigns wrote: Sat Apr 09, 2022 6:55 pm Keep in mind when bending with a press brake this chart dictates everything, from metal thickness, die opening, flange size to tonnage / foot required to make the bend. If you ever come across a good deal on a 3 ph unit keep in mind normally it's only the hydraulic motor that runs on 3 phase and can be changed out with a single phase unit, if that bumps the power load up to high for your over-taxed electrical system the hydraulic pump could be powered by a gas engine.
SegoMan DeSigns wrote: Sat Aug 06, 2022 1:37 am
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
