Mach3 Plasma ScreenSet
Re: Mach3 Plasma ScreenSet
There is a lot to building a Rotary axis interface for MACH if you want to actually cut with it. Adding another axis , axis DRO and the jog buttons is trivial BUT making it so you don't have to stop , recalculate the steps per unit for each diameter of pipe and modify things like touch off and THC functions can get complex. I suggest if its pipe/tube cutting you are after you investigate the SheetCAM Rotary Plasma plugin that does the math for you and will even let you cut sqaure and rectangular stock.
Thanks for the info Tom, I wasn't aware Sheetcam had a rotary plugin.
- FabLab
Hey,tim7878 wrote: Wed Mar 17, 2021 7:59 am hey, love the screen. really clean. anybody here know of a mach3 screen set for plasma with a 4th rotary axis? ive tried modifying the mach screen but its just honestly a little beyond me. i am happy with just the basic mach3 plasma screen, i just need the rotary axis. thx.
I don't have anything at the moment but I'll be happy to take a look it should be pretty easy to modify my current screenset.
It may take a week or two though I recently switched from Mach 3 to a Masso so I will need to fire up my Mach 3 PC to do the edits.
Do want all 4 DRO's (X Y Z & A) or would you like 1 of the DRO's replaced? If so which one?
For some reason I was unable to reply to your PM
- FabLab
I have added the requested 4th axis changes (new attachment to my original post)
As I said before I have switched to a Masso (and I don't have a 4th axis) so I was not able to test the changes but they should work.
Let me know if it doesn't work & I will take another look at it
Hirrossetti wrote: Sat Jan 25, 2020 10:27 amso you mean rip cutFabLab wrote: Thu Jan 23, 2020 8:15 pmWhat I am working on with that is whenever you hit that button a series of prompts will come up asking for X-Y coordinates and a feed rate in order to cut free the waste material and leave me with straight cut drops...
Hope that makes sense
i can send you the macro if you like
Would it be possible for you to send me the macro for the rip cut.
I am fairly new to plasma cutting on a table and didn't even know you could change the screens or add macros , I am loving the mach3 software and would like to learn more.
- FabLab
Sorry, I never finished the "rip cut" option and I have switched from Mach3 to MASSO so I don't have access to the macro anymore..
Ok thank you
Was this a good choice? I was considering MyPlasm or the MASSO, I have a premier table that I got for a really great deal but MACH3 is horrible and i just don't have the time to try and learn it. MyPlasm looks almost too easy and the MASSO just looks super cool and in touch with the current times unlike MACH. I am a CNC lathe set up and operator for over 20 years, so I am familiar with the space but HATE MACH3. I know this post is old but any input would be great.
Im not a mach fan either but have used it and it works as you know. Not sure how much time you have this new to you table but unless its giving you plenty of grief i would stick with it for a while and see how it works out and decide later.
- FabLab
I have been very happy with the MASSO, I would recommend using there THC and relay module. I used a Touch on a plasma machine i built for work and it works great as well
