Plasma Pricing app...
exapprentice
Re: Plasma Pricing app...
Post by exapprentice »
Spot on Dave
I hope that makes sense :!: you can have the same drawing but cut it from different materials and using different consumables
so the cost to cut can be different but it still has the same number of pierces.
I know the cost of consumables in the whole scheme of things isnt a biggy but it is a cost to us
I was taught old school "look after the pennies and the pounds will look after themselves" ;)
only asking if its doable :?:
Best Regards to all
Exapprentice :D
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting :(
davek0974
Post by davek0974 »
see my edit on the last post - the feature is already there :)
dropdown list on bottom of form - "Cost Per Pierce" - just set it wherever you want and recalculate, it gets saved with the job :)
tnbndr
Post by tnbndr »
his is seriously odd, the version that i download is 3.0.26 - miles ahead of your download and the reason why you are struggling i think.
Ok, it appears I am running Version 3.0.25 which was the latest.
SheetCam output is correct material size.
PlasmaEstimator is off by a decimal point.
See pics
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
davek0974
Post by davek0974 »
Thats odd, I thought this issue was fixed.
I will take another look at it tomorrow, I know what it is, just thought it was fixed.
Will post when done.
davek0974
Post by davek0974 »
Hi all
there is a new download on my site, give that a go, I think its got it right this time ;)
tnbndr
Post by tnbndr »
That fixed it.!!
Ver 3.1.27
davek0974
Post by davek0974 »
matze-atze-sch
Post by matze-atze-sch »
Tryed the new Version,
but if I hit Calculate, nothing happens?
motoguy
Post by motoguy »
I'm unable to modify the part count. It's grayed out for me. Is there a way to change that? Also, when I do change that, will it keep design cost as a fixed number, or will it multiply that x part count?
I want to say "thank you" for this program. As a brand new cutter, I was lost on how to reasonably figure pricing. I had planned on simply following Jim Colt's advice (which seems to be the basis for this program). The ability to add in finish costs, etc is great.
Also, is there a way to modify existing metal pricing, vs deleting current pricing and adding new pricing?
davek0974
Post by davek0974 »
Part count is fixed if it is loaded from a sheet cam report - the part you load is what you get, manually created jobs are variable.
Yes you can edit material costs directly - go to setup and click the "Edit material costs direct" button, its just a simple text file and should load up in NotePad, just be careful when editing not to change the format etc.
I'm glad you like it - the reason you like it is the reason I made it - I was new and stuck for price data so it developed from there;)
motoguy
Post by motoguy »
Just thought I'd add...customer had one of the panels I cut for him powder coated. Coater charged $40 per panel. The Plasma Estimator quotes $39.45 per panel. Looks like it's dead-on for pricing, at least in my area. Extremely helpful program for the "clueless newbie" like me. Thanks!
davek0974
Post by davek0974 »
davek0974
Post by davek0974 »
New version uploaded.
I have added a primer-only feature to finishing costs and fixed the printed report which was missing a few numbers ;)
As always, backup your costs files before updating, you will also need to go to setup and enter your costs for primer only option.
tnbndr
Post by tnbndr »
Thanks for the update Dave.
motoguy
Post by motoguy »
Looks like we can now modify the # of parts needed, after importing the file information from the Sheetcam report!
HI Dave
Odd problem I just installed for the last download and when I go int the program is says its version 1.048 post above says it should be 3.1.27.
What am i missing as I can see a difference in what is shown in the report above. :( :o
davek0974
Post by davek0974 »
Current version should be 3.1.30
I gather you are getting the just the updated .exe file not the whole package file - this one is only used once for the first install.
Well I scrub the whole thing but no cannot get back to an older download to install the original program to then run the final correction to have a running version????? I have gone to your web page a downloaded the last 2 packages but one is just the report file and the other is the last update.
davek0974
Post by davek0974 »
On the site there are just two downloads, first is the full install package, second is the latest update exe file, just downloaded myself and checked and they are still there and correct.
Not sure what is going on there, but you are visiting this page...
http://davekearley.co.uk/downloads/
Yes??
Ok I downloaded both the package and it installed but when I try to install v3 it stated is cannot fine the file or folder :( :o
Ok Dave
After exacting files to the folder is seems to be working and have the version number of 3.1.30 now to learn how to work it and all will be fine.
Thanks for the program and the help.
have fun
Tom
davek0974
Post by davek0974 »
No worries, glad you got there in the end :)
Future updates are just a matter of dropping the new file into the folder, replacing the existing one.
Set up your currency and units first, then the labour rates and costs.
tnbndr
Post by tnbndr »
dave:
Just a question. When I download the latest update file and unzipping into a folder there is always a MACOSX folder that contains a Plasma Estimator V3.exe file but it is only 1K in size. The root folder contains the same file but it is of substance. Is there a reason for this?
davek0974
Post by davek0974 »
Yes, I zipped it on a MAC laptop - its invisible to me, as you said, its nothing, just bin it and use the proper sized file which was from a windows system.
motoguy
Post by motoguy »
Another question...I deleted the included metal types/prices:
""2.5mm Steel CR",.00415
"3.0mm Corten Steel",.00581
"4.0mm Corten Steel",.00739
"1.2mm 304 Stainless",.00509
"3.0mm 304 Stainless",.00714"
as I don't use metric. :)
I replaced them with the units I wanted (gauge, inch plate, etc). Now, in my setup screen, the metric materials do NOT show up. The inch version do. Good deal. However, when I click on "edit materials data file directly" button, it shows ONLY the metric materials, and NOT the inch materials. I'm assuming the new version of the app is storing it's data in a different place than the "edit materials data file directly" button points to?
