Tube bending protractor
I Lean
Post by I Lean »
I made a bend protractor. :D
Trying to emulate the Mittler Bros. one, which looks like this:
Mine doesn't have the nice engraved degrees or ruler measurements, but since I usually bend tubes to match the angle of the sample I have, it might not matter. (I've been using my Angle-O-Meter previously...just a couple pieces of 3/4" flat bar with a bolt through one end so they make an adjustable "V") This style is specific to each size of tube and bend radius--this one is for 1.75" tube, 5.5" centerline radius.
If anyone has any nifty ideas of how I can get angle and inch measurements on here, I'd be interested in learning. Ideally I'd have an engraver, but I don't.
Bend protractor.dxf
Re: Tube bending protractor
Thanks for the file
1MORECUT
Post by 1MORECUT »
Nice job and Thanks for the file. :D
John 8-)
Largemouthlou
Post by Largemouthlou »
Good idea, thanks for the clean file!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
Scott F.
Post by Scott F. »
Thanks for the file... Maybe you could get a good quality decal made to fit the tool and then later on make some improvements.
Scott
Biker
Post by Biker »
Man, That nice. Good Tool. I like tools like this.
CandCNC Blade Runner Dragon cut 620 Ethercut + DTHCIV
Precision Plasma 5 X 10
Mach 3
Hypertherm Powermax 85
someguy
Post by someguy »
Very handy, thanks for the post.
_Ogre
Post by _Ogre »
add a cheapo engraver to your plasma table to get all the angles and dimensions marked
we do exhaust bending, made this one specifically for 2.5'' tubing
dichdoc
Post by dichdoc »
No help with your protractor but Ive been using this
http://www.wixey.com
With great results zero it on the end of the tube and bend. The protractor and the digital guage would be great. Wonder if you could mount it to the protractor dome how??
I Lean
Post by I Lean »
I use a similar angle finder on mine, I usually just stick it onto the die and zero it before bending. Not sure how you'd use it on the protractor all the time. It would work when mocking up a bend in the vertical plane, but not so much any other plane...
HammerDownJustin
Post by HammerDownJustin »
Made this one for the last cage I did and then gave it to a buddy
protractorbottom24x8.dxf
protractorUPPER24X3.dxf
Miller 251 Mig
Sampson Jones
Post by Sampson Jones »
Thanks guys !
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
waaiaengineering
Post by waaiaengineering »
Thank you for sharing this file will make life SO much easyer.
Davewynes
Post by Davewynes »
awesome file cheers for the share
AnthonyCoker
Post by AnthonyCoker »
Just made one today and I love it. Thanks.
Good Job, Keep up the good work.
jakeg
Post by jakeg »
8-) 8-)
Flower
Post by Flower »
Metal teacher
Post by Metal teacher »
cool thanks
techno
Post by techno »
Very nice,thanks
NWILL
Post by NWILL »
Thanks for the file. I added a few simple notches at 22.5, 30 and 45 degrees as I do not have an engraver either. This will be mainly for polygon type fire rings so I also shortened it a bit so I can fit between the steel and the press.
Bradley
Post by Bradley »
awesome thankyou
RONWB
Post by RONWB »
that's nice thanks
Searchman
Post by Searchman »
Thanks for the share
