File looks good to me, not sure what you mean.CNCCAJUN wrote:Nice file, but I just realized the "G" in GRIPS is not all there . . .
Vise Grips Rack
Re: Vise Grips Rack
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Duramax mini torch with Snap n Cut
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
Re: Vise Grips Rack
Definitely saving that. Thanks
- CNCCAJUN
Re: Vise Grips Rack
When I open in AutoCAD the bottom of the "G" is missing in GRIPS
When I open with DraftSight everything is just fine . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: Vise Grips Rack
Nice original file, love the hanging one as well!! Very nice thanks,,
Steve, the G was all there when I opened with corel..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Re: Vise Grips Rack
This will be put to GREAT use.
THANK YOU very much
Mike
THANK YOU very much
Mike
Re: Vise Grips Rack
Thanks for sharing the file.
Re: Vise Grips Rack
thank you so much for the post of this tool rack . highly appreciated .Anyone happen to know the actual dimension's ? when I imported turned out to be 15X5". Anyone got anything different ? thxs in advance
- billyeagley
Re: Vise Grips Rack
Very practical file! Thanks!
PlasmaCAM 5x10 (Samson) - DesignEdge - Hypertherm Powermax 65
Re: Vise Grips Rack
Thanks! Maybe I will be able to find them when I need them now. I spend more time looking for vise grips and tape measures than I do working.
Re: Vise Grips Rack
Thanks!!!
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
Re: Vise Grips Rack
very nice.........will have to show hubby
Toni
Toni
- HammerDownJustin
Re: Vise Grips Rack
Wish I had that many pairs of vice grips to justify making this..lol
Miller 251 Mig
Miller 251 Mig
Re: Vise Grips Rack
Thanks for the file. What a great idea! I made two of them, then slightly modified the file and made a couple of hangers for my most often used air tools out of 11 and 14 ga. Worked great. Thanks again
chattacuda from Dayton, Tennessee
CandCNC electronics, Precision Plasma V rail gantry, homemade 4'x8' water table, Sharpe Air Dryer
Hyperthem 45XP, CommandCNC, Sheetcam, Corel Draw
Re: Vise Grips Rack
[quote="mdoffroad"]15 Downloads and not one thank you.......whats wrong with some of you people!
great idea m8ty thank you for sharing
- CNCCAJUN
Re: Vise Grips Rack
Thank you again . . . . . this is the first file I have cut using SheetCAM . . . SigmaNEST is being put rest . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Vise Grips Rack
Thanks for the file,,,
- CNCCAJUN
Re: Vise Grips Rack
Hello Redlunn;Redlunn wrote:Yeah, my first post!
Here is a simple rack for holding various vise grips. I don't have any type of brake so I cut reliefs at the bend points. I plan to weld it underneath my welding table.
Redlunn
The slender rectangular boxes are relief points to make bending possible without a brake, if using a brake can I assume the center of those boxes would be the bend lines?
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Vise Grips Rack
GREAT IDEA AND I THINK EVERYONE WILL APPRECIATE THE RACK. THANKS
Re: Vise Grips Rack
cool,
thanks for the post.
Jeff M
Jeff M
Re: Vise Grips Rack
Super nice work. You did good.
Thank You,
Metalworx Fabriicators
Thank You,
Metalworx Fabricators
ArcLight Dynamics
Hypertherm Powermax 45
ArcLight Dynamics
- CNCCAJUN
Re: Vise Grips Rack
Great file, but I did I make some changes so they could be used by more people . . .
I added 2" height to the back & (4) 1/4" holes . . .
Now they can be mounted to a wall, pegboard, etc . . . and still function as designed . . .
I eliminated the relief slots and had them bent on a large brake.
Also thanks to your idea I think can design a clamp rack for small Bessy Clamps for the wood shop . . .
Thanks for posting . . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Vise Grips Rack
Thanks so much!!!!
Tim
Tim
Re: Vise Grips Rack
Designed something very similar for Air Tools, then discovered that someone is already selling something similar.
I put Keyholes in for hanging larger circle with a slot above.
Re: Vise Grips Rack
Here is the one I designed. I did a Vise Grip Rack so the tools hang from the adjustment screw...
I use 18Ga and bend them with an HF Brake. Look sellable at swap meets.
Re: Vise Grips Rack
I think this gives a reason to buy more vise grips.HammerDownJustin wrote:Wish I had that many pairs of vice grips to justify making this..lol
