Perfecting Lines for Sheetcam
donaldlsabo
Post by donaldlsabo »
Hey I'm struggling a bit with getting good lines in sheetcam. I'm curious what people find the easiest methods to getting good solid lines so sheetcam doesn't go crazy making lines and start points. Having trouble with the curves and all looking well until I export drawing to dxf and load in sheetcam where it shows splits in the lines so sheetcam makes 20 different start points when there should only be 2. It zig zags all over trying to cut everything multiple times. Please help!
muzza
Re: Perfecting Lines for Sheetcam
Post by muzza »
More details, What are you drawing with ? can you post examples
Occasionally I have a problem with sheetcam not reading the dxf properly and showing different lines so I export as a svg file or add a couple of extra nodes in the area that isn't right.
Murray
Return to “SheetCam”
