We have just introduced a great 3-stage desiccant air dryer to the online store. This is a high quality unit that first removes raw or condensed moisture down to 5 micron, then removes oil and particulate down to .01 micron, and then eliminates uncondensed moisture or humidity with the final desiccant stage. The first 2 stages have automatic drains and the desiccant stage has a glass window that allows you to see the desiccant change from blue to pink indicating that it is saturated and requires a change. With a very low dew point of -40 degrees this unit really works very well. For maximum desiccant life in shops where plasma tables are being run all day you can combine this with a refrigerated dryer after the first 2 stages and before the 3rd desiccant stage. Unit includes everthing shown below. Check it out and let us know if you have any questions, here is the link:
http://plasmaspider.com/shop/dryer_sharpe6760.html
![Image](http://www.plasmaspider.com/shop/images/plasma_air_dryer.jpg)
