Dragon DXF Weekly Giveaway - Collapsible V Firepit
Summer is getting close, the heats turning on, and it's time to get camping!
This weeks free design giveaway is a collapsible firepit, portable, and perfect for summer camping.
Be the envy of your camping neighbors using it as is, or personalize it with a custom logo or design in the sides.
If you download this design a or comment below would be appreciated!
Reason: This was last weeks Dragon DXF Giveaway and is only available for 7 days. Please check the top of the forum for this weeks design.
Re: Dragon DXF Weekly Giveaway - Collapsible V Firepit
Thanks for the file, going to make one for my buddy
Thanks awesome work
Shop-built 5x10 table powered by QtPlasmaC
Hypertherm PM 85 machine torch
Lincoln PowerMig 255C
Lincoln Square Wave Tig 255
Ermak SpeedBend Pro
Ermak SpeedBend Pro
Nice file! Thanks for sharing. If I were actually building this one, I would size the slot widths to be at least 0.010" - 0.020" wider than the actual material thickness. I would also recommend cutting a sample slot to make sure you have an acceptable fit before cutting the entire fire pit.
Very nice, thank you!
very niceee!! thank you !!!
Thanks ,good work
- tinspark
Thank you Dragon!
Will download and save this one..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
- tinspark
Yep,adbuch wrote: ↑Mon May 20, 2024 12:56 pm Nice file! Thanks for sharing. If I were actually building this one, I would size the slot widths to be at least 0.010" - 0.020" wider than the actual material thickness. I would also recommend cutting a sample slot to make sure you have an acceptable fit before cutting the entire fire pit.
If I were to burn one, I would shrink the whole thing down some. This beast is almost 3' long! and since its collapsible it is meant to be portable. This may be a two person pit to put together for some. It would likely be a bugger to put together and take apart. But doesn't have to be collapsible if someone wanted one that big. They may want to just weld it together after it is squared up.
I usually cut my logs 18-24" long +,- (eyaballed). Once I shrink this thing down to a practical size (practical to me), maybe 20"-ish, the existing slots would shrink down as well. And would need to be blown out again.
So David's advise is sound, and a good starting point based on gauge, as well as Kerf settings which affects the slot opening too.
a little slop may be better than too tight. Especially when it is time to take it apart and bag it. the less soot on the hands and everywhere else he better
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
Awesome design! I will be shrinking it down a little as Doug suggested to make it more portable but will def be cutting one. Thanks Dragon!
For portable and occasional use, I would also consider cutting this (or a smaller version) from 11 ga or 3/16. Lighter may be better for a portable unit.
Thanks for sharing this! I've been wanting to do a fire pit for awhile now, just always have other things to do. Hopefully I can slim this down a little and cut it soon.
- 1MORECUT
"Thank you for sharing this!"
- Deuling Design
Sweet pit, thanks for sharing!
Thank you been wanting to cut one out!!
