welding squares
welding squares
Good evening,
I am curious if anyone has any welding square cut files?
Zach
Zach
- tinspark
Re: welding squares
Hey Zack,
Here are a few. I have made a few of these and love them!!
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Re: welding squares
Super cool. thanks Doug! Any tips on anything special you do to finish them after welding if they need to be trued up?
- tinspark
Re: welding squares
They seem to fit together well.
I made a few of these a couple of years ago, but nothing sticks out in my memory as a problem, which I usually do remember those to elf correct if possible. .
I remember doing some grinding on the high spots that stick up after welding so that all surfaces are flat.
I have used them several times.
The large width of the squares makes them square both ways which comes in handy
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
Re: welding squares
Thank you! Exactly what I was looking for!!
Zach
Zach
Re: welding squares
Nice design Doug. I opened the file with Design Edge and did find a few minor issues. Here is the edited file.
- tinspark
Re: welding squares
Thanks David, but cant take credit for them . not my drawings. I just saved them and burned a few of them some time ago. I think I cleaned my PCM file after downloading it into DesignEdge but never exported back as a clean DXF and forgot that there were any issues. Thanks for fixing
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
- tinspark
Re: welding squares
Thanks David, but cant take credit for them. not my drawings. But they do work really well.
They definitely are no machinist squares, but work great for the welding shop.
I just saved them and burned a few of them some time ago. I think I cleaned my PCM file after downloading it into DesignEdge in my shop, but never exported back as a clean DXF and forgot that there were any issues. I do not have DesignEdge on my office PC and access DXF files through cloud services, which is where I save stuff and share when others have a request,,
Thanks for fixing
Edit: I just overwrote the prior welding square DXF file with the "few minor issues" with the one that you cleaned up. Thanks again David.
Doug
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
Re: welding squares
Me me Me attach them here please
Re: welding squares
Tom - do you need the file? i attached it to my previous reply. Are you not able to download it?
Re: welding squares
I did no understand that was the corrected file Thanks for pointing that out
Re: welding squares
acourtjester wrote: ↑Sun Mar 10, 2024 9:53 am I did no understand that was the corrected file Thanks for pointing that out
Re: welding squares
Thanks! I'm going to cut some out and have students weld them together next week. Hopefully they turn out well enough they can use them for future projects
Re: welding squares
These will make great student projects! Let us know how they turn out.
- Scratch
Re: welding squares
That’s a great idea! Something they can keep and use their whole life!
- SeanP
Re: welding squares
This is another alternative I came up with, they work really well and you have cutouts to get clamps in, I lightly tig welded the tab n slots.
Re: welding squares
Thanks Sean, I just built myself another set just a few weeks ago, but these look a little more compact, I'll sure try em'. Can never have enough welders helpers/gadgets/etc...in a welding shop.
Re: welding squares
Thank you Sean! I appericate it.
