Chevy bellhousing
trucks1948
Chevy bellhousing
Post by trucks1948 »
Does anyone have a big block chevy bellhousing bolt pattern?I need to cut out a spacer.Thank you
badassr1
Re: Chevy bellhousing
Post by badassr1 »
you bet
chevy-bellhousing-bolt-pattern.dxf
tjenus
Post by tjenus »
Be good for a mid engine plate, thanks KH
5x10 Flow Waterjet
steel 35
Post by steel 35 »
Or an engine stand who needs anything else :D
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
trucks1948
Thanks appreciate you sharing it.
gene portable welding
Post by gene portable welding »
thanks
thermal dyn 152
4 x 8 eagle plasma table
400 amp portable welder
250 amp Lincoln stick
miller cp300 w/ S-52d
miller cp300 w/S54a setup for alum
13 x 60 south bend lathe
emco mill
Amer bender
http://www.facebook.com/gene'sweldingandfabrication :)
Old Iron
Post by Old Iron »
Thank you for sharing this file with us!!!!!!!!!!
Peechy
Post by Peechy »
That's awesome !
8-)
No Class
Post by No Class »
This may be a stupid question but would this be the same for a small block chev? I had someone ask me a while ago for one.
radicalrescue
Post by radicalrescue »
No Class wrote:This may be a stupid question but would this be the same for a small block chev? I had someone ask me a while ago for one.
yeep they r the same
little blue choo
Post by little blue choo »
Hey No Class, take notes, this bolt pattern will also fit.
ALL chevy V8's
GM 4300 Vortec V6
Chevy inline 6- post 1962
Chevy 153 inline 4 cyl.
6.2 & 6.5 Detroit Diesels
Durmax V8 diesel
Generation 3 V8's
and a few jeeps that used the modified Chrysler 904 (iron Mike) trans
You never know when someone will ask for something odd that you have and don't realize it.
Rick
Rick
Arclight 9600 4x8 table
trucks1948
Good to know thanks
HomeMade Fabrication
Post by HomeMade Fabrication »
has anyone tried to use this or have a better one? I have cut this several times and it will not line up to and sbc blocks.
HomeMade Fabrication wrote: Fri Jan 14, 2022 9:33 pm has anyone tried to use this or have a better one? I have cut this several times and it will not line up to and sbc blocks.
Which holes don't line up? Personally I would drill the holes (not plasma cut) and only cut the outer perimeter of the adapter plate.
bryantar74
Post by bryantar74 »
here is what i came up with. try it. i drilled the holes out one size bit size bigger than 3/8
SBC Mid Plate4.dxf
bryantar74 wrote: Sun Jan 16, 2022 10:04 am here is what i came up with. try it. i drilled the holes out one size bit size bigger than 3/8
:Like :Like :Like
Captain89
Post by Captain89 »
bryantar74 just confirming this corrected plate above. Im about to cut out a mid plate for my LS
bryantar74
just now seeing this. it worked for a SBC 350 to power glide im not 100% sure on an ls but i think they use the same bellhousing pattern as the older small blocks.
big496
Post by big496 »
Bolt patterns are the same. The LSX uses a center bolt at the 12 o'clock position in place of the top passenger side bolt.
big496 wrote: Fri Mar 17, 2023 11:45 pm Bolt patterns are the same. The LSX uses a center bolt at the 12 o'clock position in place of the top passenger side bolt.
Thanks for that confirmation! Good to know for the future.
DJC
Post by DJC »
Does anyone have a drawing for the plate to adapt a SBC to the BOP transmission??
big496
Post by big496 »
I pulled an engine and tranny last week out of a C10. It had a bop 350 mated to it. I kept the adapter plate so I can TRY to draw or send dimensions unless someone beats me to it.
big496 wrote: Wed Mar 29, 2023 6:59 pm I pulled an engine and tranny last week out of a C10. It had a bop 350 mated to it. I kept the adapter plate so I can TRY to draw or send dimensions unless someone beats me to it.
Here's a link to the different bolt patterns http://tech.oldsgmail.com/trans_bp.php# ... ed%20here)
(No dimensions) the dowel pin and bottom 2 bolts are the same on the Chevy & BOP, the last pic in the link show a "universal" housing you may be able to scan and size to Chevy and double check your dimensions too! I junked a couple Buick trans about 3 years ago to melt the aluminum down in my homemade blast furnace to cast some pulleys, pry bar handles, and misc pcs to use on the Lathe & Mill! Thought I had 1 left, but just have Chevy!
Nice share Jeff! This is great information.
DJC
Post by DJC »
Would love it if you could make that happen!! Any interest in selling the adaptor if not?
