OXT to DXF
OXT to DXF
Hi. I was looking around on Langmuir's Fireshare site. I found a few files to download, but when I went to open them, they are a .oxt file. It is from OpenOffice, a free source program. Can anyone convert a couple files to just dxf's? Or recommend a place to do it?
Re: OXT to DXF
Have you tried to just changing the file extension, that works sometimes.
Re: OXT to DXF
Please post a link to the page with the file download so we can have a look.BMCF wrote: ↑Sat Jan 28, 2023 4:37 am Hi. I was looking around on Langmuir's Fireshare site. I found a few files to download, but when I went to open them, they are a .oxt file. It is from OpenOffice, a free source program. Can anyone convert a couple files to just dxf's? Or recommend a place to do it?
Re: OXT to DXF
Here ya go.
https://www.langmuirsystems.com/fireshare/smudge-pot
I tried changing the extension to .dxf, but it popped up an error message when i tried to open it with my CAD, and also hen i tried importing it in InkScape
Re: OXT to DXF
I forgot to add, Its not like im trying to steal someones file. The files posted on that site are free, as long as you make an account. You use to be able to download .svg and .dxf. But sometime recently, they changed the file format.
Re: OXT to DXF
Here you go. File needed to be unpacked first. I also edited to remove unwanted intersections.
Re: OXT to DXF
Thanks adbuch! What did you use to unpack it? I am using Windows whatever latest and greatest version is. I didn't see an option for it. I do use OpenOffice, so maybe that's my problem? Since I have it, maybe it associated itself with the program?
Re: OXT to DXF
Here is the process I followed. I use Bitzipper for unzipping (decompressing or unpacking) compressed files. There are other programs which do the same thing.
Re: OXT to DXF
Ok The only decompressing software i have is what came with windows. I guess it wouldn't recognize it. I'll be getting BitZipper . Thanks again.
Re: OXT to DXF
You most likely have something like WinZip for windows. My suggestion would be to open your WinZip program first, then locate your zipped file from within the program. That's what I do with BitZipper. It looks like BitZipper is no longer available, but there is an "improved" version available. Tom may have some ideas as to which one is the cheapest to use. It looks like WinZip is a free download, but I'm not sure how many files you can unzip before purchase is required.
