Looking for aftermarket Coupling for Screw to Motor for my lifter
Looking for a after market or Original MFG part number/purchase to the Torchmate Gen 1-Gen 2 Smart motor lifter statation ball screw coupling. Im sure it's on McMasters site but not sure which one im looking for
Re: Looking for aftermarket Coupling for Screw to Motor for my lifter
no, it looks like this but way over prices from lincoln https://www.torchmatestore.com/Screw-Co ... _3195.html
If that's all you need I suspect if the ID is correct for your shafts and the OD is not too large you could use almost any shaft coupling.
What size is your shaft that fits into the coupling? Shaft outside diameter? I have several sources for these at very inexpensive prices.tulsajosh wrote: ↑Thu Mar 24, 2022 11:57 am no, it looks like this but way over prices from lincoln https://www.torchmatestore.com/Screw-Co ... _3195.html
I think i got it solved, Just ordered one with smaller diameter and drilled out to the size needed but there was 2 different odd ball sizes and seems to be working just fine now. Thank you everyone
