First off I just want to thank everyone on these forums. I have found the answers to many, many questions by just finding the answers here. This time however I cannot find an answer.
Here is what I have for a system. It is home built.
G540
Sheetcam- using generic Mach4 Post Processor.
Mach4
No THC the table is 4' x 4' I haven't needed one so far.
ESS Warp9td
No probe
Here is what's going on. I have been using Mach3 with little problems. I thought I would change to Mach4 because I have problems with CV. I have spent the last three days setting everything up and testing, but the torch will not fire. After I hit cycle start it will run the g code till it gets to the M3 code:
N0010 (Filename: SJ test 14 GA Fine M4.tap)
N0020 (Post processor: Mach4 plasma.scpost)
N0030 (Date: 19/11/2021)
N0040 G21 (Units: Metric)
N0050 G90 G80 G40
N0060 (Part: SJ test)
N0070 (Operation: Outside Offset, Layer_1, T11: 14ga FineCut Mild Steel)
N0080 (14ga FineCut Mild Steel)
N0090 G00 Z38.1000
N0100 X-5.4378 Y2.7754
N0110 Z3.8100
N0120 M03
ect................
It stops there. I look at the history and this is what it says:
ESS starting Probe 0
!!!!! ESS: Probe hardware not setup. Digitize signal not mapped! Probe# 0
Can't transition from PROBING to RUNNING
MACRO ALARM: 3 MERROR_NOT_NOW
ESS: Mach4 Enabled
Do Cycle Start
Can someone please help! I am lost at this point.
Thanks in advanced!!
Mach4 torch will not fire no THC
Re: Mach4 torch will not fire no THC
It has been a long time since I looked at Mach 4, but with Mach 3 there is a probe pin under the input pins. You may have accidentally enabled the probe input in Mach 4 and it is looking for it. Or the post processor is setup to use a probe. The normal probe command in G-code is g31, but I don't see that in the g-code you supplied.
I Just checked the Input pins. The only one I had selected were the EStop, Torch Up, Torch Down, and Torch Arc Ok. I just went in and deselected the torch up down and Arc no difference. It still stops at the M03 code. I also looked through all the code and there was not a G31 even after what I pasted above. I don't know anything about post processors but can I edit the Mach3 post to fit my needs. I tried using that post but it wants me to make a tool change at M06 line.
Look at your M3 macro. It appears that it is what is throwing the error. Maybe the probing routine is in the macro.
https://warp9td.com/index.php/gettingst ... EssProbing
It looks like you're supposed to configure mach 4 through the ess plugin config, and it fills in the Mach settings.
Forgive me for not knowing, but how can I do that.
I have set those parameters through Ess Config but there is not a selection to not have a probe.djreiswig wrote: ↑Sat Nov 20, 2021 5:38 pm https://warp9td.com/index.php/gettingst ... EssProbing
I use mach 3, so I'm not sure where mach 4 stores it's macros. In mach 3 there is a folder in the Mach folder with your profile name. In that folder is a macros folder that has all of the macros for that profile. You can edit them in notepad. See if there is a g31 in the M3 macro.
Ok. Thanks. Here is what is in the m3.mcs:
function m3()
mcTHC.FireOn()
end
if (mc.mcInEditor() == 1) then
m3()
end
I have looked at the other macros in the folder and none of them have a G31.
function m3()
mcTHC.FireOn()
end
m3()
end
