BBQ pit smoker hinge ideas
looking for some different hinge ideas, instead of the regular ole cold roll and sleeve!!
- otisa2007
Re: bbq pit smoker hinge ideas
Here's a set I have used modified from a hinge file i got from here
thank you so much found some on Langmuir website cut and used them, work great problem is there huge
I will cut in the morning for the smoke box and update you on them thanks
- cstroke
This is just a concept drawing, Nothing is verified or checked.
But this is a little outside the box for your hinges..
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Chris - I like it!! This would certainly be a unique hinge for a bbq. Thanks for sharing your idea.
I designed my hinges to stop just past center. It makes for a cleaner look without bulky stops
to stop the lids from going all the way back.
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Cambam and Mach3
That's a great hinge design, and a very nice build on your bbq!
Here is a shot after completion. Thanks for the compliments.
Cambam and Mach3
Cambam and Mach3
LakeCruiser wrote: ↑Wed Oct 27, 2021 5:43 pm Here is a shot after completion. Thanks for the compliments.
Very very nice bbq trailer, great hinge ideas and nice handles as well
For my friend
Looks great! Thanks for sharing.
Is this possible to have the design ?LakeCruiser wrote: ↑Sun Oct 17, 2021 9:12 pm I designed my hinges to stop just past center. It makes for a cleaner look without bulky stops
Are you looking for the hinges or the entire smoker?3axesdesign wrote: ↑Sun Jul 24, 2022 10:32 pmIs this possible to have the design ?LakeCruiser wrote: ↑Sun Oct 17, 2021 9:12 pm I designed my hinges to stop just past center. It makes for a cleaner look without bulky stops
Let me know what you need.
Cambam and Mach3
Cambam and Mach3
Re: BBQ pit smoker hinge ideas
What did yall come up with
Small trailer pit
Very well done! I'm happy to see that you have put those hinges we worked on to good use.
these look really nice
- tinspark
Love it man!
The Burner in the back is also nice, maybe for a discada?
Thanks for sharing
Thanks for sharing
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
yes sir thank you for your help, and yes great for a disco or a pot
You are quite welcome! Happy to help as always.Squatchemup wrote: ↑Sat Apr 01, 2023 8:44 pm yes sir thank you for your help, and yes great for a disco or a pot
Looks good!!!
Cambam and Mach3
Cambam and Mach3
