torchmate post-flow
bwright
torchmate post-flow
Post by bwright »
does any one know how to change the post flow on their torchmate? I have water tabkle and the post flow is way to long after it stops cutting. It makes a huge mess. Any tips would be appreciated.
Re: torchmate post-flow
This may be controlled by your plasma cutter, and not the Torchmate software. Perhaps check your plasma cutter users manual for information on adjusting post flow time.
bwright
Post by bwright »
thank you i will check it out.
TJS
Post by TJS »
After a cut when my torch comes back and splashes up I just jog it real quick over existing sheet. If there is nothing there I put a piece under it to minimize splashing up.
Post by djreiswig »
That's what I do.
robertspark
Post by robertspark »
maybe have a torch park position added to the end of your gcode
Post by djreiswig »
That works okay if you always have your zero in the same place.
robertspark
djreiswig wrote: Wed Mar 31, 2021 12:58 pm That works okay if you always have your zero in the same place.
G53 Machine coordinates?
G53 G0 X0 Y0
ETCWeld
Post by ETCWeld »
bwright wrote: Tue Mar 30, 2021 2:05 pm does any one know how to change the post flow on their torchmate? I have water tabkle and the post flow is way to long after it stops cutting. It makes a huge mess. Any tips would be appreciated.
this was a problem for me too. I always forgot to put my piece of sheet metal there, until I just put one of our stub cans in the corner, so now one lives there and it's almost never an issue.
Or maybe lower your water level. I have my level below the bottom of the cutting grates and this has never been a problem for me. I use a draft system in conjunction with the water for more efficient smoke removal.
ETCWeld
Post by ETCWeld »
Im using a Torchmate 4800 and the side walls are almost the same size as the ribs/slats. This was never an issue with my Torchmate x.
When this machine returns home it blasts the corner and no matter what it would spray everywhere on the post purge. With my little square tube capped on the bottom, it's a non issue as long as no one messes with it.
Return to “Torchmate Forum”
