I have a question about putting on a second layer.
I sandblasted aluminum, epoxy first layer, flowed it out. Second layer is polyester clear matt for UV protection. When I applied the second layer I kept getting thin spots like I was looking at a dalmation dog.
Any thoughts?
Not obvious after cooking.
spotty second coat
Re: spotty second coat
Not sure what would cause that but at least it flowed out and looked good in the end. If you find out let me know because I have had similar issues.
That is caused by a poor ground
Sounds like back ionization, I second the post about poor ground. How close is your ground rod?
No idea actually!
back ionization from spraying with the gun to close, its charges little spots in the metal. i started holding the gun farther away and haven't had any issues since
The issue with BI and the gun being too close would be dependent on the equipment, and I would say that is would hold true for most low end or hobby controllers. For BI, you are most likely looking at a grounding issue on almost all cases. Check your resistance to ground, best with a megger, and go from there.
