no cut
Plasron
no cut
Post by Plasron »
stops on this line
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Plasron
Re: no cut
Post by Plasron »
If I draw a simple plate with holes mach 3 works fine , but, a DXF file downloaded from here, when I process it and open it in Mach3 and cycle start it run to the start of the cut and stops, the Z numbers are still actively running.
Any help would be great.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
robertspark
Re: no cut
Post by robertspark »
looks like a mill post processor.... z action but no m3....
how are you starting your torch?
thc?
what cam software are you using
Plasron
Re: no cut
Post by Plasron »
robertspark wrote: Sat Sep 28, 2019 11:53 am looks like a mill post processor.... z action but no m3....
thc?
What I’m trying to do is create cut files on my brothers laptop at my house because everything on it is licensed, when I load them in Mach3 it pops up and says controller not hooked up that’s because the plasma table Is at his house about 15 miles away from my house, when the box popped up, I kinda of took it that it wasn’t going to run the program, but, I saw on I think it was midi screen that I could run a simulation mode, but, because the reset bottom won’t reset, then I can’t run it in simulation mode.
Thanks for the reply
Ps what program can I use to test the tap file
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: no cut
Post by Plasron »
Thanks guys
The files I created on the CNC laptop, worked on the machine.
We are using a pen in place of the torch. And it is drawing the Tap files perfectly, which tells me we still Do not have the plunge hight, rapid, metal thickness etc,. set up right so far.
Thanks again for your help
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: no cut
Post by Plasron »
Update
My brother put the torch back In and cut this.
Thanks for theDXF file
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
ben de lappe
Re: no cut
Post by ben de lappe »
Probably not applicable but my TM driver software does similar. When I first open it I can select either "Connect" or "Don't Connect". Don't connect allows me to simulate cut here at home even without a machine, hopefully you got that part straightened out too.
Nice move on your brothers part, appears to have cut well. Most welcome for the file. :Like
beefy
4.5 Star Member
4.5 Star Member
Re: no cut
Post by beefy »
Plasron,
within about 5 seconds of looking at that gcode I could see what was happening.
The gcode did not actually stop and was still running but I calculated that one gcode command will take over 7 minutes to complete. Thus you think the gcode stopped. Yep just tested it in my cnc controller and that's exactly what happened.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Return to “Mach3 & Mach4 CNC”
