sheetcam problem
kennye
sheetcam problem
Post by kennye »
hey guys when i pull up sheetcam and inset a file it adds a line that is not suppose to be there and its messing my file completely up in mach 3.. how can i solve this problem Ive already unistalled and installed sheet cam .. please help and thank you .. the extra line does not show up in qcad.. only in sheetcam
Re: sheetcam problem
I think your problem is with QCAD and not SheetCam, Some software packages are not a direct transfer. What I mean is DXF files are not all the same, QCAD does have different R number and year versions have you tried other DFX version for you saving of the drawing?
Another trick I have used in SheetCam to remove things I don't want, using the contour function move the mouse to the line you don't want and click on it. then when the menu come up give it another name. Then it will put that new name in the "Layers" box. There is a small box with a check in it next to the new name, uncheck that check and the line will disappear. If you add more to that layer name they will disappear when you add them to that named layer. As long as the layer of layers are unchecked they will not be in the plan or the G-code when you post process the plan. I have used this to remove things I forgot to remove from the drawing I saved.
kennye
Post by kennye »
The contour function does not allow me to select the line. I have searched these forums to find out why any ideas?
kennye
Post by kennye »
kennye wrote: Tue Apr 23, 2019 6:05 pm The contour function does not allow me to select the line. I have searched these forums to find out why any ideas?
Disregard that statement Im working on it .thanks
kennye
Post by kennye »
What else would you suggest Ive tried what you said and figured out the contour thing but whatever I highlight I can send to a new layer the problem the lines wont highlight to make a layer and then unchecked it. I just only started having this problem recently and it will drive me crazy till I figure it out lol. I appreciate any help .thanks
Bladevane
Post by Bladevane »
Have you opened the file in a CAD program like Inkscape or eMachineshop? This should tell you whether the line is an error in the CAD file in which case it can be selected and deleted.
Les Newell
Post by Les Newell »
If you pm me a copy of the drawing and the job file (File->save job) with everything set up ready to cut I'll take a look and see what is going on.
Return to “SheetCam”
