I’ve been thinking about doing away with my Muriatic Acid bath to remove slag and mill scale and have been considering purchasing a cement mixer to use as a giant tumbler. Any thoughts on this/has anyone ever done this?
Tumbler
- Scratch
Re: Tumbler
I've used a cement mixer as a tumbler. Worked much better than the old dryer I also used. Had a slight problem with some parts getting stuck in the agitator, but works great. EXTREMELY loud though. I'd still be using it if it didn't break. It was an old one someone gave me for free.
I don't so much metalwork anymore otherwise I'd probably get one again. I'd figure out some way to keep the noise down though,
Re: Tumbler
I’ve been reading that taking out the agitators and adding a layer of ice and water shield on the outside cuts down on the noise considerably. What medium did you use. Sand, shot blast or something finer like aluminum oxide.
- East German
Re: Tumbler
Hello,
my homemade Tumbler,
Turns 25 minutes with timer.
The slag falls through the grid.
Not suitable for small parts!
Peter
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- Scratch
Re: Tumbler
The only media I used was small bits of scrap metal.
Re: Tumbler
nice design on the tumbler, looks like you can follow the progress with the see through grid. What is the diameter of the drum? The ends look like repurposed rubber tires.
- East German
Re: Tumbler
Yes Tom
there are rubber tires.The drum is 600 x 400 mm in size.
The grid is from the wall which divided East and West Germany 28 years.
The wall stood 100 meters next to my house.
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Re: Tumbler
Ok, that is an awesome story.
- East German
Re: Tumbler
motoguy wrote:Ok, that is an awesome story.
Yes, I am very happy that the wall has fallen.
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Re: Tumbler
Good people have good uses of bad things
Re: Tumbler
I have found broken ceramic tile works great in my cheapo Harbor Freight mixer. I keep the mixer outdoors to avoid both noise and dust.
