Thanks for the share.
Peter
6 sided fire pit, dxf and pcm
Re: 6 sided fire pit, dxf and pcm
What gauge material are you guys using? 10g to thin? 3\16?
What gauge material are you guys using? 10g to thin? 3/16?
I have a student who wants to make this, and he asked me to buy the DXF, while I could I told him no, you need to learn to draw, cut and weld this yourself. I am hoping it is not too bold to ask for some numbers? He has drawn it up but it does not look right, can anyone tell me how deep the fire pit area is? It looks like about 10 inches?
On mine it measures about 8.5 inches
Amada CO2 3500 laser
Amada NT1303 CNC Press Brake
HAAS ST35Y
HAAS VF4SS
Solidworks CAD design
Tube Bending
Welding and Fabrication
HAAS ST35Y
HAAS VF4SS
Tube Bending
I made a small modification to this. I added tab and slot and moved the bottom just a tad. Thanks for a great file. The slots for the tab and slot are large so you shouldn't have a problem, just make sure you remember to put the bottom in before installing the last two pieces. Also, the bend is 54.2* on this. You will need to add some bend reliefs if you are bending by hand etc. I have a press brake so I didn't have add them.
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
Thank you !!!
- david jordan
What thickness is the pit made from? Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
you technically can make it what ever you want but I modeled it in .1875 (3/16)
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
- Dennis
Going to cut one this weekend .. Thanks for the share.
