Simple question, does anyone own one?, and if so how well does the downdraft design work on it? Pretty simple design with 1 12" hole in the center of the table. Please list your table size and any relevant information.
Thanks in advance!
EZCUT Down Draft Tables?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Re: EZCUT Down Draft Tables?
Not a single owner out there than can comment?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
- see&see
12" hole?
I use a 20" hole in the side panel with 4' flex duct directly out the wall into a 3000 CFM fan and it's just enough to keep smoke out of the shop on a 4 x 4 table.
You marry into the PlasmaCam family and must accept the fact your software and hardware are proprietary. It's a for better or for worse engagement with overwhelming security. PlasmaCam controls the computer, table, hardware to their advantage IMO.
I don't have an ezcut downdraft but i do use one of the 12" fans sold here on plasmaspider http://plasmaspider.com/shop/vent_combo.html and it works great in my downdraft setup. No smoke! Works awesome.
Weldguy, how large is your table?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
I have a 5x10 down draft. 5000cfm fan, two opens cantered and 1/3 in from each end. Zero smoke.
Just scored a 24" tubeaxial fan, I think that should do it!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Do you have any pics of your table setupChris Slade wrote:I have a 5x10 down draft. 5000cfm fan, two opens cantered and 1/3 in from each end. Zero smoke.
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
