4x4 welding table help
Re: 4x4 welding table help
Being HSS, I think the taper will kill that bit pretty quickly. I'm not sure what would be needed to cut out the nitrided taper...carbide?
sr guy, yes that may help, but you would probably need a magnetic drill press to make sure your not actually making the hole worse. The taper may not be significant enough to work about. I am going to add the hole in the test piece that I uploaded earlier for checking hole quality. The top can be cut out of 1/4", 5/16" or 3/8" plate, so cut one test piece out of a similar thickness. Of course the thinner top will not be as robust as a lighter top.
Here is a toggle clamp that can be used with the fixture table. A 5/8" bolt is welded to the bottom of the clamp and can be secured to the table with washer and nut. I have not shown the pivot fasteners. You could weld 3/8" rod or bolt together with 3/8" bolts and lock nuts. All the parts are 1/4" mild steel. You could also cut some rubber hose to slide over the handle for comfort. With these basic files you should be able to scale up/down or modify to suit your needs. I have used these basic profiles hundreds of times over years of fixture building.
Thanks a million!!!!!!
WOW...thanks hemichargersrt8! This clamp is exactly what I was looking for in December and will certainly come in handy very soon. Thanks again, I am pumped...most useful file for me in a while.
- greenweanie
Thanks for the share hemichargersrt8!
anyone lay this out to cut on one sheet of 4x8?
thanks for sharing the plans>
Thanks for posting
Have not cut, but thanks for the share!
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
This is amazing stuff. Should be stickied, in my opinion.
Many thanks.
Many thanks.
this is awesome you need to pm your address to me ill send you some money for these plans. Person on ebay wants $30 i would be more than glad to send you that. This saved me alot of time!
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
What a grade design. Thanks so much. This will be a big help.
Thank you, amazing!!!!!
Here is the next style of clamp for the fixture table. This "push" style can be very versatile. The parts can be modified to suit your needs. I don't know if the pictures are self explanatory. If more information is needed to assemble any of these accessories, just let me know.
What software is this designed in? The work is
What software is this designed in? The work is very nice
Thanks, I use Solidworks
Thanks for posting those drawings are slicker then Whale Snot.
I would love to be able to draw like that I just cannot get the concept in my little head (visualize)
- steel 35
Very much appreciated
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Thanks for sharing.
Has anyone cut these on plasma. I have a plasma cam. I only have 311 software. I cut these and the tabs were to small. It was cutting from inside. Anyone have any luck?
Vanquish, what part are you cutting? Is the slot too small or the tab too large to fit together?
Thanks hemichargersrt8, think I will make a few of those clamps to tack onto my existing flat top table where needed
- steel 35
I thought I had converted three sets of the drawings to size and shapes that would work for me but anything I added or changed does not connect to the existing lines, if I modify the existing lines it works but it is Very time consuming and they are hard to Join together and it shows up very quickly in sheetcam anyone tried and have success modifying? Unmodified they would cut as they are drawn very well.hemichargersrt8 wrote:Vanquish, what part are you cutting? Is the slot too small or the tab too large to fit together?
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
