Well I downloaded QCAD v3.12.5 from QCAD.
http://www.qcad.org/en/qcad-downloads-trial
Before You Download...
The packages on this page contain the free, open source QCAD software which you can use free of charge for any purpose.
The packages are bundled with free trial versions of the QCAD Pro add-on and the QCAD/CAM add-on. The trial versions of these add-ons are not intended for production use but give you a chance to try before you buy.
The QCAD Pro and QCAD/CAM add-ons terminate after 15 minutes. To continue to try these add-ons, you need to restart QCAD after this.
To uninstall a trial add-on, click on the button with an 'X' beside the add-on in the 'Trial' window.
To use the QCAD community edition without any proprietary add-ons, simply uninstall all trial add-ons.
You can order QCAD Professional or QCAD/CAM from our Online Shop and download the full version immediately. QCAD 3.12.5
I have had a small amount of luck in doing a DXF to SVG full conversion. I have been able to get it to connect most node segments but it leaves overlapping nodes when it does the connect. When you delete the one overlapping node it will somewhat change the contour as well.
I have also tried PDF Creator version 1_7_3 _setup.exe ONLY, anything newer won't have the TO SVG FILE conversion in it. For my MS Windows 7.
http://download.pdfforge.org/download/pdfcreator/list
If you download this program make sure you go into the download install box and click the OPTIONS and UNCHECK all the CRAP added toolbar load-ins.
Other possibilities are:
This will need a computer programmer to compile and get this in a loadable state - don't know if it works either.
http://sourceforge.net/p/dxf-svg-conver ... attachment
http://sourceforge.net/p/dxf-svg-convert/patches/1/
Or
Very PDF ----
http://www.verypdf.com/dwg-to-vector/dx ... erter.html
Anyone else have any insight to this DXF to SVG conversion?
