What is this start cartridge that you mentioned in another thread? Is this a wear item? replacable? I have determined that there is something wrong with the cutter. Somtimes it doesnt fire....IDK why.
Thanx,
Jim
Start cartridge?
- admin
- Site Admin
Re: Start cartridge?
The replacable start cartridge is found on Thermal Dynamics plasma cutters. It is a replaceable item that can cause starting problems if it is worn out. I am not familiar with your plasma cutter, but it likely does not have a replaceable start catridge. It may have s pring loaded "plunger" located where the electrode seats in the torch head. If it does, check to be sure the spring loaded "plunger" moves freely and that the mechanism is clean. Also confirm that you have VERY clean and dry air entering your plasma. Dirty or moist air can contaninate your torch lead and torch head causing starting and cutting problems in addition to prematurely worn consumables and poor cut quality.
admin
admin
- CPK_Jim
Thanks, that looks alot different than mine. I think my problem was dirt in the tip, I cleaned it out good and let the air flow thru for a while and it works ok now. If I ever get some $ I will look into better machine.
Jim
Jim
- admin
- Site Admin
Good to hear Jim. I figured it was something like that.
admin
admin
