Blasting sand
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
Patrick Waite
Blasting sand
Post by Patrick Waite »
What is a good blasting Media to use in a blasting Cabnet. Im putting something together here and wanted to know what every one else used to get good resalts before powder coating.
Patrick
FiveORacing
Re: Blasting sand
Post by FiveORacing »
For powdercoating I would say Aluminum Oxide. It's a uniform size and doesn't pulverize to dust as quickly. I've tried sand and glass and I found that AO just leaves a better profile and the powder flows out better. Lasts much longer in my Empire cabinet before it's sucked away by the dust collector too. I get 60 and 80 grit. For aluminum I turn the pressure down to about 25psi for the last pass.
I pay .66 a pound for brown aluminum oxide.
oregonsigns
Re: Blasting sand
Post by oregonsigns »
silicon carbide is the best. 100 grit, low to no static , long lasting and cuts quick.
Return to “Abrasive & Texturing”
