correct way to cut circles - CW or CCW
- trucks1948
I seem to have forgotten the correct way to cut circles ,on inside cuts is it clockwise or counter clockwise?Is it the same or opposite on outside cuts?Thanks Jim
Re: correct way to cut circles
Counterclockwise for inside cuts, clockwise for outside. The "good" cut edge is supposed to be on the right side of the plasma stream, as viewed from behind the direction of travel.
- trucks1948
thanks jim
- dgeorgester
Re: correct way to cut circles - CW or CCW
Could someone explain the science behind this?
Samson 510
Hypertherm Powermax 85, Lincoln 256
AutoCAD
AutoCAD
Swirl ring direction causes the plasma jet to spin and create a cutting direction like a saw blade.
From the internet:
"Cut Direction must be considered when programming the plasma cutter. Like a router, the direction of travel the plasma torch takes will affect the cut quality. This is because the holes in the swirl
ring produce a swirl in the plasma jet. The finish side of the plasma cut is the right side of the cut
when facing the direction of travel."
From the internet:
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
Gas Swirl Explained.....this is copied from a post I made on another site a while back, to answer tha same question regarding gas swirl in a plasma torch:
I am not aware of a particular document that explains the mechanism that makes plasma cutting directional?so I will just explain it here.
Early plasma cutting system (in the 1960?s) created a plasma arc using laminar gas flow through the torch?.essentially this means that the gas flow came straight down through the torch. These systems became popular because they would cut stainless and aluminum?..something you could not do with the other thermal cutting process of the day?.oxy-fuel cutting. Plasma was also much faster?.but had a drawback?severe bevel on both sides of the torch.
Engineers that were developing improved plasma systems at the time discovered that by swirling the gas flow through the torch consumable parts?the cut edge angularity would shift from one side of the kerf to the other. So?.with clockwise gas swirl?.a torch that was driving into a plate (moving away from you) would produce a rather severe bevel on the left side of the cut, and a slight bevel on the right side of the cut. With a ccw swirl?the bevel would reverse.
Gas swirl in the torch has been more refined over the years?in fact Hypertherm oxygen plasma torches use a complex two phase swirl in the torch that controls edge angularity, creates a centrifuge effect (slings cooler, heavier gas molecules to the outside of the nozzle bore) that dramatically improves consumable life, and also controls the arc attachment point on the electrode..again for longer life. On some plasma systems there are available swirl rings (the consumable part in the torch that controls gas swirl) that can swirl cw, and ccw. If (as an example) you are using two torches simultaneously to cut strips from a plate?you would use a cw swirl in the left torch (square kerf on the right of the torch) and a ccw swirl on the right torch (square kerf on the left of the torch) in order to get square edges on both sides of the strip.
99.9% of cutting with plasma is done using cw swirl. A good way to remember the proper cut direction is to think of cutting a ring. The inside diameter is always cut in the counter clockwise direction, the outside diameter is cut in the clockwise direction?this keeps the squarest edge on the id and od of the ring?and the more beveled edge stays in the scrap.
Most CAM software for plasma cutting (the key word is ?most?, often if software that is designed for milling or routing?which are also directional?will allow the programmer to set direction.) will automatically choose the correct direction?as the standard swirl rings for plasma cutting are always cw swirl. (ccw swirl rings are rarely used?are not even available for many plasma torches, and usually are special ordered when needed).
Hope this helps!
Hope this helps!
- dgeorgester
Thanks, that really clarifies everything. Just goes to show you, one learns something new every day.
Samson 510
AutoCAD
AutoCAD
