Some mounts we made for heavy chain
2” thick AR 400 cut on our table. Power max 85. They are mounts for holding chain to help stabilize smaller logs in a bypass clam on a log loader. The outside edges on the larger pieces I faced in the mill after cutting, the smaller rounded piece is just as it came off the table, no grinding other than a touch on the backside to take off the slag that didn’t come off with hammer, the edges are untouched. That’s some heavy cutting at 2.5 ipm. Not sure that Hypertherm had this in mind when they made the 85?... Glad it is not sync because running arc stretch like this can eat tips nicely.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
Re: Some mounts we made for heavy chain
Man that's impressive, you are into some heavy duty stuff that's for sure, thanks for posting.
I agree - those are some very impressive cuts on that thick material using you PM85. And also with your assessment of the better economics of the Duramax consumables vs. the Sync cartridges for your particular application.
- tinspark
Yes AMAZING cuts!
2.5 IPM is definitely a crawl, but must be the sweet spot based on your pics..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
WOW! Well done, very impressive, thanks for posting
- SegoMan DeSigns
Now that you did 2" with your 85 I will have to find some 2-1/2" to tryout the 105 on
Go for it. I would not say the edge was great at all, but at least it was better than hand cutting with oxyfuel.
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
Cutnweld - just curious how long (how many cut inches) your nozzle and electrode lasted cutting that thickness of material? I have a Powermax 85 on my cnc table - but have mainly used it for materials 1/2" and under for my hobby purposes.
I am not sure, David. I put in 2 or 3 nozzles to do that. 74 minutes cutting total. Its almost as bad as dry firing the torch because the top steel blows away and the bottom can hardly be reached, really hard on stuff.
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
Thanks for the information! I guess it's still cheaper to just replace nozzles than the entire cartridge is this were the sync system.
