A while back I coated my water table and slats with Ospho to cut down on rust that was building from a bad batch of plasma additive. It worked ok for a while then it turned into a science experiment with layers of skin forming on top of the water. It got real nasty.
Would it be a bad idea to clean it out real good, then fill the table with a mixture of water and vinegar or muratic acid to sit covered for a day or two? Has anyone done something like this help get a fresh start on the water pan? I hate to refill with $150 of additive and have the same reaction then start over.
Acid or vinegar to clean water table
Re: Acid or vinegar to clean water table
Would certainly be a good idea to kill any bacteria before an expensive refill but I wouldn't use muratic acid. I am afraid that even covered it may end up rusting every steel part in your table like rack and pinion gears, rails, etc. Vinegar or bleach may be better. I wonder if you could just spray down all surfaces with straight vinegar or bleach rather than diluting it and filling the entire table.
How about Hydrogen peroxide since Covid you can get small spray bottles, I thing Walmart sells 1/2 QT bottles for about a $12.00
